flow #'s on local mildly ported heads
all flow@28"h2o
int exh
.200 134 114
.300 191 163
.400 233 190
.500 256 208
.600 257 219
.700 262 223
I know these are not great numbers but what are the mid lift compared to some of the top sponsors heads? I dont plan on buying another set of heads as these have much more in them with a bigger cam. through a 12 bolt with 4.10 gears it dynoed at Thunder racing 400 hp 388 tq with Mac headers and cutout behind y pipe and car runs strong with the little c1 cam 222/222 -.566/.566 112 lsa cam . Yes this is with a ls6 intake. 12.9 a/f ratio .
If you want to bash then find another thread, I only paid 600 for all work done on the heads and they are pushing my car as fast as some of the big dog heads at full weight with a cam of this size. I just want to compare mid lift and down low. Thanks ,Chad.
all flow@28"h2o
int exh
.200 134 114
.300 191 163
.400 233 190
.500 256 208
.600 257 219
.700 262 223
imo,on a street car the mid lift numbers are more important than peak numbers.my patriots flow 194(intake)and 147(exhaust) at .300 lift.so you are right about there with some stg. 2 heads at mid lift.you got a hell of a bargain for the power you got.i'm jealous. The Best V8 Stories One Small Block at Time
I was saying that his LS1 heads were acting like LS6 heads with great midlift numbers. Geeze you can't even give a compliment without getting railed.
YOU SAID THEY WERE GOOD??!!
YOU SAID I HAD GOOD NUMBERS?!!!
I'LL TEACH YOU TO BE NICE AND SAY THINGS LIKE THAT
You might want to re-read what I typed a bit slower.Once again...great numbers all around track and dyno.
