Why change lifters and trays?
1, It seems that LS7 lifters are considered to be upgrades over other stock lifters.
What is it about these lifters that make them an upgrade over other lifters?
Is it always advisable to change the lifters with a new cam even if the old lifters do not appear to have any visible wear to the roller surface (does the wear occur internally?)
2, I also see a lot of time people suggest changing the lifter trays as well.
Why is this? Are the trays different for the LS7 lifters?
Thanks in advance.
They are an updated design but basically same thing.
That being said I reused my stock 60k mile lifters when I did my cam swap and it fine, but next time I pull the heads ill be upgrading to morel or Johnson lifters which are def an upgrade over stock pieces..
Ls2 lifter trays are an upgrade an help prevent the lifter from twisting in the tray, again I reused my stock ones with no issues...good luck bro
Tool Steel Body
Tool Steel roller and axle, OEM is 1010.
OEM cam designed for .700" Wheel, Aftermarket lobes designed using .750" Wheel
All Morel lifters are QC and leak tested. Most batch test.
Morel are 100% made in OHIO
Pricy but I have NEVER had a customer call me and said I wish I hadnt gone with the Morels.
Tool Steel Body
