anyone running mast 215s?
Old Sep 29, 2013 | 08:33 AM
Treys06gto's Avatar
Default anyone running mast 215s?
Looking for some new heads for my 03 z06. My last set on my gto was some AI 243s that worked great. I really want to try something else. Haven't seen much on anyone running the mast 215 heads. Seen them on Ed Curtis website. There a little bit cheaper than afr and trick flow. Anyone using these and how do you like them?
Old Sep 29, 2013 | 05:04 PM
Always2Slow's Avatar
Mast heads are great. We're running a set of 235s and they run the number. For a 215 head they are probably the best you can buy.
Old Sep 29, 2013 | 07:05 PM
Treys06gto's Avatar
I see slot of people runnin mast heads just want some feedback from some 215 owners. I'm in Hawaii so its a big time difference and with work difficult t times to call mast or Ed Curtis.
Old Sep 29, 2013 | 07:28 PM
miami993c297's Avatar
All what you need to know is inside my thread:
https://ls1tech.com/forums/dynamomet...1rwhp-fti.html
Christian
Old Sep 30, 2013 | 12:37 AM
sbcgenII's Avatar
Where are you finding Mast heads for cheaper than AFR? I think you're mistaken.
Old Sep 30, 2013 | 05:16 AM
Treys06gto's Avatar
I have a brand new spring kit so I'm deduction the price of that
Old Sep 30, 2013 | 05:24 AM
Treys06gto's Avatar
Christian
So I heard that the mast 215 are the new etp heads like you had. Is that correct? Did you flycut?
Old Sep 30, 2013 | 08:11 AM
JakeFusion's Avatar
Super Hulk Smash
The MAST 215s with the options I'd like... hollow-stem intake valve, dual valve springs, Ti retainers, rocker stands, and milled... comes in around $3300 for the set.
Yikes.
I'd consider AFR 215s Mamofied at that price point.
Old Sep 30, 2013 | 01:26 PM
Hi Treys06gto,
You obviously didn't find the opportunity to read my thread...
Post # 67, you're welcome.
https://ls1tech.com/forums/dynamometer-results-comparisons/648228-video-idle-plus-streetability-wot-my-511rwhp-fti.html
And yes, that's correct.
Christian
Old Sep 30, 2013 | 02:10 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I have the predecessor to the MAST 215 heads, the PI heads. The car drove phenominal when I was NA, but then I decided NA wasn't enough and tossed a few psi of boost on them and now it's really fun.
Old Sep 30, 2013 | 03:57 PM
allan808's Avatar
Aloha! bradah
