5.0 lsx
Old Oct 2, 2013 | 02:24 AM
87FBomb's Avatar
Default 5.0 lsx
iv read a few things here and there i want to be different i know why and whatever but i want a 5.0 lsx just so i can say yea its got the little motor in it and still blow people away
my questions are would stock ls1 pistons work since they are .03 over stock 4.8/5.3 bore size
would i need to mill the heads to keep compression around 10:1
and are there any differences flow wise between a 4.8 and a 5.3 heads?
anyone please chime in im new to the ls world just finished my fist sbc swap and wanna tackle this animal next
Old Oct 2, 2013 | 09:13 AM
wildcamaro's Avatar
Stock ls1 pistons will give you 5.7 if you use a 5.3 bc they have same crank.you need a 4.8 with ls1 pistons do what you want...I didn't do the calculation but I assume it will be close to 5.0
4.8 flat tops with ls1 bore should be at least 10:1
And no there's not any difference between 4.8 and 5.3 heads
Old Oct 2, 2013 | 12:08 PM
snowman47's Avatar
A 4.8 crank is 3.268 so if you use a 3.85 piston you would get 304~ci. which will give you your 5.0L. If you use ls1 standard borepistons (.118 over) youll get 312~ci. which would be something just under 5.1L. Do some research and price checking to see what would be more cost effective for your bottom end. Plenty of sponsors on here do a great job porting the factory 5.3 heads and will far exceed the flow requirements for a little 5.0 on everything but a max effort situation. Figure out your goals, do some research and get a hold of some sponsors. Good luck
Old Nov 9, 2013 | 06:00 AM
Bumpin' Yota's Avatar
Would it he worth the expense to bore a 4.8 to 3.904" bore making a rev happy 5.1L?
Old Nov 9, 2013 | 08:08 AM
wildcamaro's Avatar
Be the experiment and try it out! Would be interesting to see the results...
Old Nov 9, 2013 | 02:10 PM
Well its an additional 600$ for the forged ls1 pistons plus boring plus rebalancing...
Old Nov 20, 2013 | 08:42 PM
knuts82's Avatar
Im running a 3.905 bore Manley piston on a Gen4 rod and a 4.8 crank.
313ci. along with twin 61mm Turbos on Ethonal. I love large bore small storke motors.. Nothing like the sound of a LS motor spinning 8000rpm.
Old Dec 2, 2014 | 01:38 PM
What are you doing valve train wise to support 8000+rpm?
Old Dec 2, 2014 | 03:56 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Just say your 5.7 is a 5.0?
Old Dec 2, 2014 | 07:49 PM
cuisinartvette's Avatar
Youll spend a lot of money to have a smaller motor with less power esp the loss of torque on the street. Maybe on a forced induction setup may have less bottom end stress but you WILL spend a ton on valvetrain pieces to avoid carnage. RPM motors are expensive.
understand a "different" build and all but sometmes people get carried away with stories about short stroke motors high rpm fast blah blah
BTDT.
always wanted a 69 Z/28 til I drove a few. Biggest turd on the planet, sound good thats about it;or go drive a 5.0 mustang 2v same thing
Go bigger, always
