P0327&P0332 after LS6 IM swap
The car only has 33k, sensors worked just fine until I swapped the LS6 IM and now both of them are bad...? What to do? Any suggestions before I have to take the IM off again?
Probably best to pull the intake and replace both sensors and the harness. Be sure you use a torque wrench to tighten the new sensors or they won't read properly. I'm guessing you disturbed the wiring or sensors. Also the new intake may have damaged the old harness. Its fits differently than the LS1 intake on the bottom.
