replacing valves
Old Nov 6, 2013 | 12:53 PM
VerdeZ28's Avatar
Default replacing valves
If i were to swap valves from one head to another, would I have to do a new valve job? the idea I am having is replacing ls2 valves with ls6 valves on a 243 head
Old Nov 6, 2013 | 01:40 PM
KCS's Avatar
KCS
Moderator
Shouldn't have to. They're all the same sizes and angle. You're swapping to the hollow stem intakes and sodium filled exhausts right?
Old Nov 6, 2013 | 01:55 PM
VerdeZ28's Avatar
yeah. im not sure either. but thats the plan, replacing the ls2 intake and exhaust valve with the ls6 hollow intake valve and sodium filled exhaust valve.
Old Nov 6, 2013 | 02:02 PM
KCS's Avatar
KCS
Moderator
If the valves and seats aren't all beat up, it'll be fine. Lapping them in wouldn't be a bad idea either.
Old Nov 6, 2013 | 02:13 PM
VerdeZ28's Avatar
well the heads in question had a valve job done by tea along with the stage 1 porting. thing is i have a set of ls6 valves and would rather have the lighter valvetrain. I dont know if when TEA does a valve job, if they match it to each valve or just run a generic cnc program that assumes the valves are within spec.
Old Nov 6, 2013 | 03:16 PM
KCS's Avatar
KCS
Moderator
They more than likely run a generic program for a 2.0" valve with a 45 degree seat. In that case, you are good to go.
Old Nov 6, 2013 | 04:34 PM
slt200mph's Avatar
I would call TEA and ask them the question since they did the work. Why speculate on it.
Old Nov 6, 2013 | 05:07 PM
A.R. Shale Targa's Avatar
I lapped my LS6 (new take outs) into the 15,700 mile seats on my 241
heads and they worked just fine. In your case as long as the TEA heads are
stg ones and not the larger valved stg twos you should also be fine with a
simple lapping. The only thing that will hurt flow a few cfms will be that your
new valves won't have the backcut that TEA does to the valves. You could
just number them when lapping and run them over to a local machine shop.
