As long as we're asking, what does it take for 10's with...
Next, the sway bar: It's there for a reason, right? What is that reason? What does the sway bar do, and what will happen if I remove it?
Third, are skinnys street legal? Do they affect handling? (I was almost sure that they did...)
I mean the AC doesn't affect how the car handles or looks... It only affects whether one can get cold air.
How do you know what your car weighs? Put it on a scale, you cant just go by what the door says. Also just because you use skinny's at the track dosen't mean you have to drive around on them. Just change them for the track, and drive around on regular tires for the road. The sway bar mainly helps you in corning for turns. Really I bought my car used and the sway bar was already gone. Never even realized it until 3 months later when I tried removing it for the track. I then took it off my other car as well.
A nice fiberglass hood should shave 30 lbs. Chromoly A-arms is 14 lbs
Chromoly K-member is 31 lbs. Buy a dry cell battery and save 20 lbs and mount it in the back for a better 50/50 weight.
30 lbs hood
60 lbs seats
14 lbs chromoly a-arms
31 lbs k-member (will have to see if it fits w/headers)
That's 135 lbs. And not a single "sacrifice." I like this. Would a carbon fiber hood be even lighter? I hear they're making a ws6-style carbon fiber hood soon...
To run in the 10's with my car in street trim and to be very driveable. I dont want to give up my AC or anything else. No overly rough idle or extremely loud exhaust and full emissions.
Basically I want it to be stealth a total sleeper capable of blowing the doors off most anything out there. I know I'll never be the fastest but I will beat most ricers and anything stock that anyone builds.
I've considered FI and NO2 but am not interested in either. NO2 is not practical for everyday use and FI seldom delivers at the track what the dyno shows.
This leaves the $20k 427 stroker. Tons of torque and good driveability.
With no weight removed other than the spare tire, jack and factory disc changer my car weighs 3600 with me in it.
I figure 130 MPH 1/4 trap speeds should be enough
plug the figures into here to see how much crank HP you need
http://www.corral.net/tech/horsepower.html
At 3600 lbs I will need 630 crank HP to run 130 mph so a 550 RWHP 427 should be able to do it.
I realistically figure in the $25K area for engine and suspension and drivetrain mods.
Sure it can be done for less but this car will look and sound and drive very close to stock.
And in my opinion, a 10 second nitrous car isn't really a 10 second car: It's an 11 second car with nitrous.
Well, I never said it had to be completely streetable. But I had figured as much by this point. I have moved on to asking: can a 38x car with the above attributes do it, and how streetable would THAT be?
They mostly run NO2.
Good place to start:
https://ls1tech.com/forums/drag-racing-tech/17319-weight-reduction-list.html
That is the weight reduction thread. To get a H/C M6 into the 10's you'll need a lot of that.
Its up to you what you can live with and what you can't.
Myself, A/C is necessary but a stereo is optional.
All about the sacrifices you are willing to make.
https://ls1tech.com/forums/showthread.php?t=17319
Having converters in place and a full exhaust will get me by for emissions
My car is a 2002 so I have no EGR or AIR. At least visually my car will pass.As far as stealth no one needs to know about the extra 80 cubes right?
As far as weight reductions I think I can drop about 100 lbs with a bit of work but I think for a weekend toy I'm not too concerned about getting every .10th. Breaking into high 10's would make me quite happy
Nine Ball had a 38_ big bore and he went 11.1's I think.
Good luck to you.
I have 14 boddles at my use, 6 of which are 15 pounders. I will run you the best 51 of 100 if you want. Of course I will put at least 500 dollars on it so I can refill my boddles.
So PSJ and others, am I hearing that even with a 38X setup, it would still be somewhat tricky to get into the 10's? Even with the new lsx and stage 3 heads that everyone is coming out with? I can do enough weight reduction to at least compensate for the cage, if not more. Isn't 550 rwhp a pretty doable number with that many cubes?
You are way off course. To get that much power even out of a 427 the cam is going to have to be aggressive, the headers will need to be 1 7/8, and the exhaust note will be loud. Let me help you get there a different way.
You said that FI isn't for you b/c most of the people with FI setup aren't running the numbers the dyno says. DUDE you are trying to get a full weight
sleeper in the 10's. HAHAHAHAHAHA
Sorry to be a dick, but it's funny.
Anyways back on track here. The HP calc you are using is neat but much more goes into running 10's then 130MPH. Here is a great option that would defentially get you the HP you will need, still be more of a sleeper (until you open the hood) then a 427 and you will have the power full time.
Buy a forged 347, 382, 387 or something along these lines. Get the motor built with around 8.5:1 compression. Get a set of very good heads. Buy a Turbo or Supercharger kit that can make at least 15psi. You should beable to make 600+ RWHP with this etup even running a Z06 cam and full exhaust.
You will trap well over 130 MPH. As long as you can hook at least a 1.7 60ft and you drive the car well you should make 10 sec passes all day.
If you have a A4 then you will also need a 3500-3800 stall for the setup and if you have a M6 I would suggest a 373 gear with 26" tall tire or 410 gear with a 28" tall tire. That way you will get through the 1/4 in 4th.
Sorry about the Nitrous reply. Just being a smart ***. If my cars were as fast as my mouth I would have a few 7 sec LS1's.
Anyway.
The tricky part comes down to great 60ft and driving skill.
550 RWHP should be good enough if everything is done properly. Also if you do all the weight mods it will defentially help. Take that spare tire out like I said and put it back in if you take a road trip in your track car. Chances are probally unlikely. The new intake/TB and heads should defentially give you a 20+ HP gain from what most other setup's have. I think 520RWHP is a better guess because you will be going through a 8.8/12bolt/9" and a 373 or 410 gear. This will defentially take some power, but is a must if you drag race.
I am also saying 520 tops, and it might take a 422 or 427 to get there.
