As long as we're asking, what does it take for 10's with...
Old May 10, 2004 | 03:11 PM
  #61
JZ'sTA's Avatar
BTW the K member will work with headers, depending on what kind you might have to make a small notch in the K member. Also the C/Fiber hood might be 5 lbs lighter but not much. The fiberglass hood is like 17 lbs, hard to make a hood that much lighter.
  #62
black_knight's Avatar
Originally Posted by JZ'sTA
I am also saying 520 tops, and it might take a 422 or 427 to get there.
See, that's what I'm getting at. When you step up from a 38X to a 4XX, you're looking at an additional $9-15 thousand! For that kind of money I could just go FI and call it a day. So before I do anything I need to know if I can do it with just a stroker.
I mean I don't have any sound requirements and I only need to pass OBD2, so I'm not quite as bad off as that other fellow.
Old May 10, 2004 | 03:13 PM
  #63
That's cool. And, hey, 5 lbs is 5 lbs and I hear the carbon fiber hood is going to be relatively inexpensive. Plus carbon fiber is just plain cool, and it already comes in black.
Old May 10, 2004 | 03:23 PM
  #64
JZ'sTA's Avatar
Well if you have a black car then it would be nice. If the price is right I would probally do it as well, just to be different.
I really dont want to say what you can and cant achieve with what combo. I honestly believe the 408 will get you there as well. However this is extra weight. So then we go to the 388 all bore or 382 stroker. I still believe (personially but I have no way to back my oponion) you can get over 500 RWHP with a 382 or 387/388 through a 12 bolt.
The best way to get the most accurate info will be to get the car on a scale. I believe you will realize your goals are easier to achieve or harder then you thought. Usually the cars weight is different then what the door says.
Old May 10, 2004 | 03:32 PM
  #65
70 TA's Avatar
You are way off course. To get that much power even out of a 427 the cam is going to have to be aggressive, the headers will need to be 1 7/8, and the exhaust note will be loud. Let me help you get there a different way.
You said that FI isn't for you b/c most of the people with FI setup aren't running the numbers the dyno says. DUDE you are trying to get a full weight
sleeper in the 10's. HAHAHAHAHAHA
Sorry to be a dick, but it's funny.
Anyways back on track here. The HP calc you are using is neat but much more goes into running 10's then 130MPH. Here is a great option that would defentially get you the HP you will need, still be more of a sleeper (until you open the hood) then a 427 and you will have the power full time.
Buy a forged 347, 382, 387 or something along these lines. Get the motor built with around 8.5:1 compression. Get a set of very good heads. Buy a Turbo or Supercharger kit that can make at least 15psi. You should beable to make 600+ RWHP with this etup even running a Z06 cam and full exhaust.
You will trap well over 130 MPH. As long as you can hook at least a 1.7 60ft and you drive the car well you should make 10 sec passes all day.
If you have a A4 then you will also need a 3500-3800 stall for the setup and if you have a M6 I would suggest a 373 gear with 26" tall tire or 410 gear with a 28" tall tire. That way you will get through the 1/4 in 4th.
No offense taken LOL
Its been done before and it will be done again.
Maybe I was misunderstood.
Ok when I say sleeper I mean it dont want it idling like a race car with open exhaust and stuff. I'd like the car to be somewhat civilized.
And I realize I will have to do some suspension work to get it to hook and that I wont see 10's on my street tires
There are guys running in the 9's on motor only and I realize they are running bigger cams and no dash and seats and stuff but I think it is possible to pull high 10's with 550RWHP at 3600 LBS.
130 MPH with GOOD traction should be enough.
Old May 10, 2004 | 03:48 PM
  #66
JZ'sTA's Avatar
Yes 9's all motor with a 2800 lbs car A3 Trans Brake 4500+ Stall Shifting at 7000+RPM's, and wheeliebars. Also huge cams, and probally 13:1 compression with 100+ octane fuel. I believe you are in a totally different game in a different park.
Anyways
You cleared up what you ment in sleeper a little more and made your goal more achieveable. (Is that even a word?)
I still believe it will be easier and would cost around the same to do a FI setup. You could do a complete Longblock from someone like APE for 7-10 thousand including intake/TB/Cam and 347 cubes-408 cubes.
Then another 6 thousand for a Super charger, and you have 9 - 12thousand left (depending on what size motor you go with) for tires/ suspension/ roll cage/ fuel/ install/ tune.
Old May 11, 2004 | 11:40 AM
  #67
So, bottom line:
With an M6 with a 3600 lb raceweight (that includes driver and cage), a 382 stroker with stg 3 H/C, all the boltons (including lsx), a 12 bolt or 9" rear, stg 3 clutch, torque arm, and slicks...
Would it run 10's? Or would it require more cubes?
Old May 11, 2004 | 12:27 PM
  #68
PREDATOR-Z's Avatar
So, bottom line:
Sorry dude but I have to quote tagwash and say "Whoever crosses the line first , WINS. Does'nt matter how you do it"
My vote goes to N2O. Myself I'm going with forged 347 and a 200 shot DP. Very stretable 10:8 of about 420 rwhp N/A. At the push of a dual stage, there you are Hello 10's.
Look at my sig, I'm close to that with a stock motor, no headers and 150 (aprox) dry shot NOS.
Old May 11, 2004 | 01:12 PM
  #69
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
black_ I think it could but it's on the edge, you'd have to launch hard and hook great.
Old May 11, 2004 | 04:26 PM
  #70
Thanks PSJ. Any other experts? Any other comparable setups? Anything I'm missing that would make it more of a sure thing (besides nitrous)?
Old May 11, 2004 | 04:32 PM
  #71
Hardtop's Avatar
My car is 100 lbs lighter than your desired raceweight. I'm sure my car would run 10's with a 382 stroker.
Bruce
Old May 11, 2004 | 05:27 PM
  #72
Bruce
Hardtop, you're exactly the sort of fellow I've been looking to talk to! Are you running a cage? What weight reduction have you done?
Good choice of cam, BTW...
Old May 11, 2004 | 05:36 PM
  #73
JZ'sTA's Avatar
Well if hardtop is that close and only 100lbs lighter then I believe you can make it to 10's. You have to be a Very skilled driver and you have to launch at 6000RPM's and HOOK. Like I said before I have no facts but my oponion is that you can get there.
Good luck to you.
Defentially PM me when you finish and get to the track so I can know how you did.
Old May 11, 2004 | 05:42 PM
  #74
Good luck to you.
Thanks. It won't be anytime soon, but I'm researching it so I can know what I'll need.
For instance, if I went FI then I wouldn't need a pulley.
Old May 12, 2004 | 07:11 AM
  #75
Hardtop's Avatar
6 point steel bar, not chrome moly. All the required safety equipment. BMR k-member, ! A/C, ! spare & jack, ! pass seat. 3505 lbs. with 3/4 tank of gas.
Bruce
