Pushrod length with LS7 lifters
Old Dec 2, 2013 | 09:35 AM
redtan's Avatar
Default Pushrod length with LS7 lifters
I am doing a h/c swap in a few weekends and want get a general idea of what length pushrod I will need with my setup. I will be measuring on the spot, but I only have one chance to do this whole thing so I want to be in the ballpark, order a few different lengths and then after measuring pick one of those. So the closer I can estimate it, the better I will be when ordering.
Setup is comp LSL/LXL cam, 0.040 cometic gaskets, 243 heads shaved 0.030 and new LS7 lifters.
I've heard that LS7 lifters are 0.060 taller or something, so they require a shorter pushrod. Is that the case? In total that means I need a pushrod close to 7.300 after the milling, thinner headgaskets and new lifters?
Old Dec 2, 2013 | 09:58 AM
JOHNNY59's Avatar
get yourself a adjustable pushrod checker and order 1 set of pushrods.
Old Dec 2, 2013 | 12:02 PM
redtan's Avatar
I get that's the best way to do it, but unfortunately I cannot just tear down the car to measure and then wait 2-3 days for the correct pushrods to come.
I need to be able to pick out the correct pushrods out of the tool box after measuring, and this entails having several different lenghts already purchased and I don't want to buy 20 sets. Need to narrow it down to a few through calculation and then I would measure for the exact one I need. Just trying to figure out this lifter situation.
Old Dec 2, 2013 | 12:09 PM
JOHNNY59's Avatar
I see your point. give Texas Speed a call as they're good with LS1 motors.
Old Dec 2, 2013 | 07:46 PM
BrntWS6's Avatar
My 243's were shaved .020 from TSP and they recommended 7.4" PR. Had to send them back and get 7.35" with LS7 lifters and OEM gasket.
Old Dec 3, 2013 | 01:43 AM
ls1 1990 VN's Avatar
LS7 lifters are a direct replacement for OEM lifters...They do 'NOT' require a different length pushrod.
Measure!
Old Dec 3, 2013 | 07:59 AM
JakeFusion's Avatar
Super Hulk Smash
7.375 would be my guess if you don't want to measure. You have a very wide preload window with LS7 lifters, so you could be off by .050" and it'd still technically work. 7.425" would be the length with a smaller base circle cam and stock everything. Milling the heads and running a thinner gasket means you can take that off... 7.425 - .041" = 7.384" length. 7.375 is as close as you're going to get off the shelf.
BTR has them for $94. Best price I've found on standard 5/16" pushrods.
Old Dec 3, 2013 | 08:07 AM
Exidous's Avatar
The cam base circle plays a role as well but I too would suggest 7.375" as a starting point. LS7 lifters are the same length as LS1's. I have what you see below and needed 7.425" (measured) with a .051" gasket and unmilled GM casting heads. You lose .011" to the gasket and .030" to the mill. My 228r also had a smaller base circle than a stock ls1 cam.
A 7.375" will net you .009" less preload than I have given same cam base circle and valve stem lengths.
End of the day.....measure twice (or 16 times) buy once. The length checker is <$15 from Summit or Jegs and I'm sure TSP could have the proper rod out to you in a couple days after you measure.
 Michael S. Palmer
Old Dec 7, 2013 | 11:32 AM
poltergeist 02's Avatar
I have personally measured LS1 lifters compared to LS7's. The LS7 lifter cup sits .050" higher than the LS1 lifters. I ended up using 7.375 pushrods with GM MLS gaskets and stock 799 heads to achieve a preload of .085" average (was measured with a comp pushrod length checker and dial indicator). In your case, using a .040" gasket (-.011") and heads milled .030" (-.030") I would suggest using a 7.325 - 7.350 length pushrod.
