How to get 400RWHP from A4????
brian
You dynoed your car in 2nd ... It should have made more than 373 in 2nd I would think. If you do a 231/237 I would suggest a 4000 stall, if you do the 224 cam I would suggest a 3500-3800 stall. This is be very important.
Here's the dyno chart.
Fresh LS6 shortblock, stock LS6 bottom end components
AAP Stage II 5.3L heads milled .030 (11.1:1), 222/224 .571"/.571" 114 LSA cam
Erson single springs, titanium retainers
ASP pulley
Since then I've added the Holley/Lingenfelter intake and the NX wet kit.
More info on my website.
It also passed the roller emissions test with flying colors.
(Somehow they overlooked the visual thanks to Ben Franklin).
I just dropped her off yesterday for :
- fresh Erson single valvesprings, valvetrain checkup
- ARP rod bolts and new crank/main bearings if needed
- ARP head bolts
- new J-Swiss timing chain
- new oil dipstick tube (creased badly from being bent around)
Should be solid as a rock, supposed to get her back Friday afternoon.
Bad30th
Dan
You should be able to do it with a 224 cam.
Dyno numbers aren't everything. the funny thing was...
I could only dyno 360's on one dyno(dyno jet), then the first pull with that same tune on a better setup dyno jet pulled 388 so go figure
im not worried about peak numbers just as long as my A/F is dailed in.. its nice to say u have over 400hp, but if you can get from point A to point B quicker that means squat
the tea heads were 1470 when i got them also so that wasnt a bad deal for some budget heads at the time since most others were 2000+ in price
