One bank 20% leaner
Issue im having is bank1 is 15-20% leaner than bank2. I have tried hotter plugs with more gap, triple checked wires, and checked for intake and exhaust leaks. The injectors just got back from being cleaned and tested. Fuel pressure is right where it should be. All exhaust primaries appear to heat up evenly to the touch. Plugs look good, just lean. Fuel crossover is clean and rails are clean. Compression test shows all cylinders are about the same and number is fine. Idle vacuum and speed are fine...
Im out of ideas, anybody got a guess?
How are you checking for vacuum leaks? The best way is to watch your STFT's and 02's then spray carb cleaner around the intake.
Let us know what you find.
I replaced both o2 sensors after blowing the head because they were both dead.
Checked for leaks by spraying starting fluid around the intake ports and not a single flinch. The ports all look flush to the head and I checked the orings before putting it back on. The top and bottom sections of the intake were never separated.
Both heads were surfaced 0.005 to clean them up.
I plan on taking off the exhaust to see if I can see a leak around the gasket surface.
Even if the tune was wrong, I would not expect to see such a large difference bank to bank.
I took the exhaust off and there are no signs of leakage on the gasket on either side.
Also took the intake off and both sides were flush the gaskets are all fine and in their slots.
Still looking for that smoking gun :/
Looks like the heads are coming back off....sigh...thanks for the help guys.
