Daily Driver Cams
Old May 7, 2014 | 08:19 AM
  #41
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I daily drove an FTI HellRaiser cam.
229/236 .631.631 112+2 and loved it. I wanted to go bigger but sold the car first. Torque was amazing, and too end simply screamed.
Agree with Jake; drive ability is subjective. Mine even had solid motor mounts with a poly Trans.
Old May 7, 2014 | 09:48 AM
  #42
CHEVELLEPOSSE's Avatar
01 ss 6sp 228r lt's heads cut outs ls6 int. Manifold PAC 600 springs 7.4 pr. Hf Mellon slp double roller. Idles like **** till I got a dyno tune then idled perfect pulled hard I did high 11 sec quarter miles wasn't the best going threw parking lots but definetly a DD as Long as the cops don't get behind you and hear it in Cali we have strict emission laws
Old May 7, 2014 | 09:50 AM
  #43
Oh ya that was a 112 lsa
Old May 7, 2014 | 11:28 AM
  #44
COSPEED2's Avatar
LS1Tech Sponsor
Most cams can be run on a 3000 stall with no issues, it all depends on the tuner also, not just the driver.
Old May 10, 2014 | 08:50 PM
  #45
TransAmTimmy's Avatar
Originally Posted by dr_whigham
Who spec'd your cam? Comp?
Tick performance did. I was trying to stay fairly street friendly. what do you think ?
Old May 10, 2014 | 09:47 PM
  #46
GMRL's Avatar
My 5'2" 120lb, blonde, petite, vet tech, 25 year old wife DDs her TA.(not trying to brag, maybe a little)
02 full bolt ons, 224r 112, yank 3600ss, 3.23. Never heard a single complaint about drivabilty from her. She loves the thing to death. Drivability is a matter of opinion, Im sure I dont have to tell anyone that though.
Drives great on the street, feels like stock, with an additional 100 hp.
Old May 10, 2014 | 09:49 PM
  #47
99Bluz28's Avatar
With 6.5* overlap it'll have a nice cam sound and a little bit of shake, should work fairly well, but I probably would have went a little smaller like the BTR Stage ll cam.
http://www.briantooleyracing.com/nat...-camshaft.html.
Old May 10, 2014 | 10:08 PM
  #48
COSPEED2's Avatar
LS1Tech Sponsor
It appears everyones spectrum of "drives like stock" is very wide as well.
Old May 11, 2014 | 03:12 AM
  #49
slowsol95's Avatar
What size converter did you end up going with for that cam? If it were me with that cam I'd go with a good tight 3600 like the ss3600. Sure you might be able to get away with a 3000-3200, but the performance will be better with the 3600 and I doubt you could tell much of a difference between the two driving around town.
Old May 11, 2014 | 03:13 AM
  #50
slowsol95's Avatar
FWIW I daily a 4000 revmax with a stock cam and love it.
Old May 11, 2014 | 09:28 AM
  #51
99'CajunFirehawk157's Avatar
I know the answer to this but does anyone not run a aftermarket stall on their cam, just stock stall?
Old May 11, 2014 | 11:07 AM
  #52
JakeFusion's Avatar
Super Hulk Smash
You really can't run a stock stall with a big aftermarket cam. You'll blow through your brakes and it will be a pain in the *** to drive on the street safely.
And that's different than having a lumping, surging monster cam with a loose stall. It's actually about being able to stop without rolling through red lights and such. You need to raise the idle up to 1K or so on most aftermarket cams and with a 1600 stall, you simply don't have enough headroom to actually drive the car.
Old May 11, 2014 | 11:14 AM
  #53
COSPEED2's Avatar
LS1Tech Sponsor
You can idle nearly any cam at less than 1k. Most will be between 800-950 max. If it will only idle at 1k hot then something is wrong.
Old May 12, 2014 | 02:25 PM
  #54
PhantomR/T's Avatar
ms3 with a 3800 stall when it was still a DD.
Old May 13, 2014 | 12:35 AM
  #55
Currently I have not picked up a stall yet. I was looking at a 3200-3600 but I'm also stuck on injectors as well. I saw SS3600 was recommended by tick so I was looking down the road for the stall. So its either the 36lb injectors or a stall this month lol...
Old May 13, 2014 | 01:07 AM
  #56
Exclamation
So is the consensus this is a "big" cam:
Old May 13, 2014 | 02:37 AM
  #57
slowsol95's Avatar
The 229/236 cam he got IMO is on the larger end of the medium sized cams. It would work really well with a 3600 stall and 3.23-3.42 gears and will be tons of fun even in a daily driver.
Old May 13, 2014 | 05:00 AM
  #58
dr_whigham's Avatar
The Scammer Hammer
I don't think it's a big cam. Good medium stick, it is. Took me about a yr to outgrow it.
OP, get the Yank 3600, and get some supercharged Pontiac GTP injectors. They're 42# at our pressure of 58psi. They can be had on the cheap if you search around...
Good info here:
Www.ls1tech.com/forums/showthread.php?t=1547928
Old May 13, 2014 | 05:40 AM
  #59
COSPEED2's Avatar
LS1Tech Sponsor
We do offer injector resizing services as well, that way they are new filters/baskets and flowmatched. Cant beat the price or service! We can get you 36-50lb options.
Old May 13, 2014 | 07:59 AM
  #60
JakeFusion's Avatar
Super Hulk Smash
It's a mid-sized cam. I usually look at total overlap @ 0.050" to determine "size," since that affects how it drives. Anything under 8 degrees can be tuned to drive pretty nice. Anything under 2-4 degrees can be daily driven without too much protest by most people.
That 226/234 113 is at 4 degrees... so it would be a nice driver IMO.
A cam like mine has 16 degrees of overlap. So it starts to be on the ragged edge as to what people can stand. Once you dip into the 20s or even mid 20s for overlap on a 346, I think that's probably a bit overkill. Hard to tune it to behave properly, because there just is so little vacuum at low engine speed. The T-Rex had 25 degrees of overlap. Probably about as big as you want on anything that sees street time.
