Daily Driver Cams
Old May 13, 2014 | 03:23 PM
  #61
99Bluz28's Avatar
Originally Posted by 99'CajunFirehawk157
So is the consensus this is a "big" cam:
That would be a nice DD cam, but I would still go with at least a 3200 stall TC .
It's not a big cam, unless you're referring to using it with a stock stall then yes it's a big cam.
FYI, if you want to use the stock stall then I'd go with a small cam like a 212/218 114lsa, even then you would still benefit from a higher stall TC.
Old May 13, 2014 | 03:49 PM
  #62
TransAmTimmy's Avatar
just found those Supercharged Pontiac injectors 110 for 8 shipped.
