those with ls2,l92 builds come on in please
I have been over to dyno page looking and really haven't seen much up there. of course I didn't spend endless hours looking either .
Still weighing out options and configurations as to stroke and bore combos to help me succeed and keep consumption and slap down and maintain drive-ability.
I mean yea i am doing this on a budget but, also that doesn't mean i'm skimping on parts. I've seen great deals on here and instead of paying 2500 for a crank i don't care to wait around for a good deal either.
So I'm thinking 4.250 stroke and .030 over should bet me pretty good CID .
so here is what i'm thinking 4.125 crank 6.125 rods and .030. on ls2 block gets me in the 4xx + cid right.
But yea I was thinkin you can go 4.125 in a ls2 block. Maybe someone will chime in. My block is an 09 block so it more then likely had the l92 heads. The heads I have are ls3. I'm thinking open up the exhaust ports and just smooth the intake with a 421 should be pretty awesome, just trying to figure out pistons, cam, and compression. I should be able to run pump gas as long as I pull timing via laptop. Not to sure I've just been reading around
Lots of builders do not recommend more stroke than bore.
http://texas-speed.com/p-760-wiseco-...25-stroke.aspx
