Worth the cam change?
That came will not be THAT bad in driveablity, if you can get the tune right it will idle fine and drive just fine. It will drive even better if he was to gear it properly. You could probably leave it but I would think a 3.73 would be great, or be a baller and go with 4.11
My cam idles like a ******* Prostocker and drove like **** in 1st gear and low RPMs, then I geared it and it drives pretty close to stock considering it has nearly 70 degrees of overlap if my math can be trusted.
FWIW if you want to swap to the 11/32 pushrods like Bozz said, call one of the places that does custom push rods. Get one that tapers at the ends, it will save you a little bit of weight but still give you the deflection resilience you need in the middle of the rod. You always have to think about saving weight if running those Xtreme Energy lobes.
Trend makes 3/8" pushrods with double taper that have been proven to fit cathedral heads as well, but it's a tight fit, so it has to be verified.
You can determine RPM range by the intake valve closing event and how early the exhaust valve opens.
That 230/236 cam is a nice profile. Will peak in the mid 6000s and carry to 7k rpm if you want to spin it that high.
So at 1700 RPM in 6th gear, the throttle will be open enough not to feel any surge with a 9* overlap cam. With my 10* overlap cam, if I just slightly opened the throttle at 1500 rpm in 4th gear (30 mph) the surging stopped.
Russ Kemp
Russ Kemp
Changing my cam with a wider LSA fixed all my drive- ability issues. Then some people keep the trans in a lower gear & cruise around at 2000+ RPM and say their car drives like stock?
I have a customer with a 2004 ZO6 with ported heads 2.02/1.60 valves, 62 cc .052 gasket (11.0 CR), 1.75 American Racing headers, catted midpipe, LPE GT 11 215/231 118 lsa cam.
He wants more mid range to top end power and refuses to have any surge at low rpm/light throttle. So I recommended a 228/240/117+4 .600/.600 cam. Should be installing it in the next couple of months. Also I will be retuning the PCM with my Hp Tuner & FJO wideband.
Russ Kemp
http://www.ws6project.com/user_stor/catalog/fuel-rails/
