Best Head and Cam Package
Old Mar 10, 2014 | 01:17 AM
87camarolsx's Avatar
Default Best Head and Cam Package
Hey everyone im swapping an ls1 out of a 2002 z28 into my 87 camaro im rebuilding the block with stock specs but i want to upgrade the heads and cam for a little power and give it a nice sound at idle. I want to run heads that dont require block work. So i think i want to run ls2 heads and just need help deciding on what cam and head upgrades to do.
Old Mar 10, 2014 | 12:12 PM
Mavn's Avatar
"I MAID THEESE"
Ls7 lifters, 243 heads, dual springs, hardened pushrods, ls2 timing chain.
I'd go like a 228r cam. Mild but sounds good and makes power.
Just my $.02
Old Mar 10, 2014 | 01:26 PM
Just my $.02
Would you mind linking me a good cam if i used the upgrades you listed.
Old Mar 10, 2014 | 07:02 PM
Mavn's Avatar
"I MAID THEESE"
http://texas-speed.com/p-1148-texas-...-camshaft.aspx
Get the cam kit dual
Springs, but also get ls7 lifters. This is a nice all around cam
Old Mar 11, 2014 | 04:35 PM
WS6ICK2k's Avatar
Look into a cam from Martin at tick performance also. The 228 is a great cam but it has been outdated. There have been many advancements in valve events since it has been released years ago.
Another for the 243 heads. Some ls7 lifters had lead to noisier valve trains I would run BTRs instead.
Old Mar 11, 2014 | 05:24 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Just give me a call. We can discuss your combination and goals and I would be happy to recommend a combination that is right for you. Also if you would like a custom specced cam over an off the shelf cam I can do that for you as well. We don't charge any extra for custom cams. We'd be happy to do it.
Lonnie
Old Mar 11, 2014 | 06:55 PM
96capricemgr's Avatar
If you want a "little power" and sound then a cam only will do it, would be a HUGE step up from whatever you had without the cost of heads. I mean a cam only LS1 will double the available factory HP for that year car.
Old Mar 11, 2014 | 07:14 PM
JakeFusion's Avatar
Super Hulk Smash
I'm fond of TEA heads and EPS cams. Mike @ TEA and Geoff @ EPS are great to work with.
I also recommend Tony Mamo @ AFR, Ed Curtis at Flowtech Induction and Brian Tooley to spec out a heads/cam package.
Old Mar 11, 2014 | 07:32 PM
01ssreda4's Avatar
There is so many vendors its hard to make a final decision sometimes. I'm running a Cam Motion grind (228/232) and AI ported 243 heads and it runs pretty well.
Old Mar 11, 2014 | 10:45 PM
WS6ICK2k's Avatar
Can't go wrong with anyone on this list.
Old Jun 3, 2014 | 10:41 PM
I got some feed back from tick and Texas speed and it seems hp wise they will be about the same. So is one brand better than the other. I know through Texas speed I can get a package deal with pushrods and springs for about 600.
Old Jun 3, 2014 | 11:37 PM
chevybayboy's Avatar
Can't really go wrong with any vendor on here
