lq4 cylinder wall problem
Old Mar 13, 2014 | 12:15 AM
JacobIroc's Avatar
Default lq4 cylinder wall problem
Bought this lq4 complete minus accessories, starter and harness. Payed $350. Tore it down, cleaned everything up and seen this... I won't be able to see it from another angle until I get an engine stand. Can this be fixed with a resleeve?
Also, what are complete 317 heads going for now? Thanks guys
edit: forgot pictures
Attached Thumbnails lq4 cylinder wall problem-img593.jpg   lq4 cylinder wall problem-2.jpg   lq4 cylinder wall problem-1.jpg
Old Mar 13, 2014 | 05:55 AM
JRENIGAR's Avatar
What part of the bore is that on? IE, top or bottom?
Old Mar 13, 2014 | 08:11 AM
KCS's Avatar
KCS
Moderator
That looks like the very bottom, which should not cause any problems unless you're building a stroker. You can see how far down it is from where the rings are at BDC, so it shouldn't cause any problems with ring seal.
If it were me, I'd use it and just hone the block. The hone will smooth out any high spots that could damage the skirt of the piston.
Old Mar 13, 2014 | 11:22 AM
JacobIroc's Avatar
You're right. It is at the very bottom. It is on the top side of the cylinder bore at the bottom near the crank. If that clarrifies
Old Mar 13, 2014 | 03:39 PM
Old Geezer's Avatar
Buff the rough edges down, hone the block, and run it...........
Old Mar 21, 2014 | 06:49 PM
JacobIroc's Avatar
Here are two more pictures of the damage.
The first is the picture is of the cylinder wall.
The second is under 7. Is this the water jacket? Is this repairable?
Thanks guys
Attached Thumbnails lq4 cylinder wall problem-20140319_133246.jpg   lq4 cylinder wall problem-20140321_163340.jpg
Old Mar 21, 2014 | 08:32 PM
99 2500's Avatar
That's the oil gallery from the oil pump, I would not waste time with that block
Old Mar 26, 2014 | 03:17 PM
JacobIroc's Avatar
Well with the damage, anyone know if this block is worth anything to anyone?
Mock up block is the only purpose I can think of, other than maybe turn it into a table? haha
