need help. valve keepers are not coming off. heads on car
I bought the comp cams head on motor valve spring compressor. But when i compress the springs the valve moves down with everything else.
I've tried smacking the retainers with a hammer.
I've tried the TDC method hoping that the valve will hit the top of the piston and release itself.
I've tried using an air fitting to keep the valve pushed closed. As i tighten the bolt the valves move down anyways and the air gets released
If it helps, I'm replacing the retainers, valve spring, seats, and stem seals, so i don't care if i have to damage anything but the valve.
I'm two seconds away from zapping the springs with a plasma cutter
I've never used air, I've always just shoved rope through the spark plug hole. Have the piston slightly below tdc, then rotate the crank to compress the rope and to put pressure on your valves.
That happens a lot, because over time you get a little varnish in there that sort of glues everything together.
Spray a drop of Easy Off oven cleaner on top of the keepers and let it sit for a few hours. You might even want to do that a couple of times.
Then use a good penetrating oi. Like a 50/50 mix of acetone and auto trans fluid, and let that sit for a while. WD-40 is not a penetrating oil.
When you whack it with a hammer, hit the outside edge of the keeper. For those that you can't reach well, get piece of steel long enough to reach the keeper, and whack that with a hammer. Be sure to use a sturdy piece so that it transmits the force instead of absorbing it.
DO NOT place the piston at TDC and push down on the valve. That can bend the valve stem. All you need to do is bend the valve stem about 0.5mm or so and it won't seal.
Well since I cant hit the rear retainers with a hammer, this rope deal is sounding pretty good.
Also, since I have determined that the design of the comp cams spring compressor is pure junk, I went ahead and spent about $220 for the LSM sc-167. Sounds expensive, but its worth it if you factor in the price for all those gaskets and time to pull the heads. Hopefully between that and the rope trick I can get them.
@ Spy2520, I wouldnt use an air hammer and chance it slipping and hitting anything
Which Comp tool are you using? The LSM you mention buying looks nearly just like it.
If you don't pay attention when torquing the compressor down it will put too much sideways angle on the keepers. Use a medium to screwdriver to lightly pry it around and they will likely come loose.
@Thunderstruck507, you're exactly right. The angle starts off good on the comp compressor and as you tighten the angle progressively gets worse. I'm glad I'm not the only one that noticed that.
I found out the hard way by bending all 4 of the supplied bolts while in the head. Thank goodness the bolts are cheap because something is going to bend, either the bolts or the head threads, and i would have screamed if i had damaged my afr heads.
The compressor that i bought is somewhat the same but the biggest difference is that it swivels which will keep the angle where it needs to be.
I honestly think that because the comp one pushes at the wrong angle it puts pressure on the keepers not allowing them to release
