LS1 cam swap help
Old Mar 23, 2014 | 01:42 PM
N2Ojunky's Avatar
Question LS1 cam swap help
I have my motor torn down and this is my first LS so I don't know very much "yet" but what do u need to hold the lifters up and what length and thread bolts do I need to pull the cam out and are there any tricks like rotating the cam and so on. Thanks for any help and info.
Old Mar 23, 2014 | 02:08 PM
68BBChevelle's Avatar
Rotate cam over few times to push lifters up in trays. I used a dowel rod to hold lifters up pushed in all way to back of block. I used intake bolts as a cam handle.
Old Mar 23, 2014 | 02:19 PM
N2Ojunky's Avatar
Thanks. On my way to the house to try it. I bought 5/16 steel rod and 5/16 wood dowel rods.
Old Mar 23, 2014 | 02:57 PM
jsteele90's Avatar
i use heavy duty zip ties to hold them up and thread a couple water pump bots into the cam.
Old Mar 23, 2014 | 10:14 PM
N2Ojunky's Avatar
I have it done yeah. I used 5/16 rods and 3 M8 bolts from lowes. I know this is a little off what I asked but do I need an o-ring on the oil pick tube where it goes in the oil pump?
Old Mar 24, 2014 | 02:21 AM
Cheezebandit's Avatar
yes there should be an O ring on the pick up tube .. it might still be inside the oil pump if you removed it...
Old Mar 25, 2014 | 12:59 PM
93civEJ1's Avatar
I am getting a MS4 cam for my LS6. This is my first LS engine as well. Am enjoying it so far.
I will be new to this motor as well. Coming from a 2JZ supra.
I am a little confused on the measuring for my pushrod length when it comes to that. Also how can I measure or tell to make sure that my head has not been milled. I bought the car used from a lot that did not know too much of the history.
Old Mar 25, 2014 | 01:53 PM
Krod127's Avatar
I use the same method, if you can't a lifter to stay up so you can get a towel all the way in an extendable magnet from the top works great.
Old Mar 30, 2014 | 08:43 PM
GMC5.3's Avatar
Is the dowel rods and magnetic tricks both used for the same purpose to hold the lifters up? I'm gonna be doing a cam swap in a few weeks and this would be some good info
Old Mar 30, 2014 | 09:58 PM
N2Ojunky's Avatar
Yeah pretty much. I bought a 5/16 ×3' or 4' metal rod and cut it in half ($5). I found it in the nut, bolt, and tool section at Lowes. I also got 3 bolts M8×1.25 about 3" long to help get the cam in and out. This worked flawlessly for me.
