Cam suggestions
Old Mar 23, 2014 | 04:48 PM
The_TA_Kid's Avatar
Default Cam suggestions
Hey guys I'm new to the Ls family. And I'm just curious on what cam to go with on my stock motor. How big of a lift can I go that won't hurt me? And has anyone used the polluter cam and what's your thoughts on it? Thanks
Old Mar 23, 2014 | 05:30 PM
HCI2000SS's Avatar
That cam is way to big for a stock motor LS1 IMO! Waht are your plans for the car?
Old Mar 23, 2014 | 06:17 PM
The_TA_Kid's Avatar
Oh. I had heard that cam is good as long as I use a 4000 stall. But my plans for now are 4000 stall. Not sure on cam yet and eventually different heads and 102 mm intake. But I'm going for cam and stall first. What about a ms3?
Old Mar 23, 2014 | 07:34 PM
HCI2000SS's Avatar
Well having a stall will help a lot! Since you will be doing that along with heads and intake either cam would probably work great... but you will need more agressive gearing to take full advantage of it.
Old Mar 24, 2014 | 12:07 AM
99Bluz28's Avatar
I'd take a look at the Tick performance, Street Heat Stage 2.
http://www.tickperformance.com/tick-...1-ls6-engines/
Old Mar 24, 2014 | 11:49 AM
Sales@Tick's Avatar
What is your main intended usage of the vehicle?
That IMO is 50% of which cam you should be choosing for your vehicle.
IMO it's even more important than what supporting mods you already have installed or will be installing.
Combination is key.
Old Mar 24, 2014 | 12:09 PM
The_TA_Kid's Avatar
Well it's not my daily but I do drive it a lot. So I'm still looking for it to be somewhat dependable. I looked the cam up the guy showed on the link earlier, the cam that tick makes street heat stage 2. I'm looking for some performance out of the cam. But I definitely want a nice idle
Old Mar 24, 2014 | 12:25 PM
Sales@Tick's Avatar
If you wanted something a little more aggressive, we have a LS2 version of the Street Heat Stage 2. It works very well in LS1/LS6 powered vehicles.
233/240 .619/.588 112+2 are the LS2 specs.
Old Mar 24, 2014 | 02:21 PM
The_TA_Kid's Avatar
Martin do you have a link to this cam you can post?
Old Mar 24, 2014 | 02:34 PM
Fry_'s Avatar
This might seem like a stupid question, but does your car even have headers yet? If not stop worrying about what cam to get and get your basic bolt-ons done and a GOOD 4000rpm torque converter installed then get a cam. In the time you do that you'll have time to research what cam would best work for you.
Old Mar 24, 2014 | 02:39 PM
The_TA_Kid's Avatar
Yes fry I already have long tubes and a complete exhaust system. Not cats. And a good tune, and a mild built trany. But will need retune after the cam...
Old Mar 24, 2014 | 02:43 PM
BoricuaHec01's Avatar
Formally Simplɘ Jack
Don't mean to hijack but just wondering the same about a cam. I want to put a mild one in but is it highly recommended to do a stall first? I want to go with a 3600 and almost every cam I've looked at recommends anything 3500 or above. I really don't want to put a sleeper cam but something around the middle. Possible with stock tranny/stall?
Old Mar 24, 2014 | 03:06 PM
Fry_'s Avatar
Had to ask, it's not to uncommon to have some newbie in here that wants to put a cam in there 100% stock car, sometimes with stock valve springs and push rods LOL.
Old Mar 24, 2014 | 04:13 PM
Furious1's Avatar
Unless it is super mild, you will need a stall. 3600 will work for most applications, but you could probably go less if you have to.
Old Mar 25, 2014 | 10:16 AM
Blackpanther99's Avatar
3600 stall is more than good.
Old Mar 25, 2014 | 11:49 AM
Sales@Tick's Avatar
This is a 97 C5 with a stock LS6 intake, cold air intake, LT headers, high flow cats and a cat-back exhaust.
Old Mar 25, 2014 | 05:24 PM
The_TA_Kid's Avatar
Martin@tick
I'm going to go with the street heat stage two. Ls1,ls6 cam.
231/238 .61x"/.58x" LSA 113+3
What spring and pushrods do I need for this cam?
Old Mar 25, 2014 | 11:22 PM
99Bluz28's Avatar
Go with the BTR dual springs
http://www.tickperformance.com/brian...l-lsx-engines/
Old Mar 25, 2014 | 11:54 PM
COSPEED2's Avatar
LS1Tech Sponsor
We can sure get you set up with a custom cam as well. There are many vendors and each has their own tried and true ideas as to what is correct. You can choose the stall you want, but just remember A) you WILL need a good trans cooler and B) you will be stuck with it. Plus, our custom cams are cheaper than alot of other companies off shelf cams and we have free shipping.
If we can help, give us a shout.
Old Mar 26, 2014 | 09:33 AM
Sales@Tick's Avatar
Martin@tick
BTR # SK001 (I prefer the Ti retainers, but steel is also a great choice)
If your heads are not milled I would recommend a 7.400 5/16" .080" Comp Magnum push rod.
We sell a cam package that would include that camshaft, BTR Platinum spring kit(SK001) and Comp(Trend) 7.400" 5/16" .080 wall push rods for 695.00 shipped to your door(free shipping).
