Quick oil pan question
Old Mar 30, 2014 | 04:00 AM
blue-03-ss's Avatar
Default Quick oil pan question
Just a quick question. I'm building a turbo 5.3L and I'm wondering will the LS7 oilpan/pump work on this block? It looks like it should bolt up fine just from the pictures that I've seen online of the pan. Just thinking that the oil passages to and from the pump might be different on the LS7 block just for the dry sump set up?
I'm asking because I like the idea of a dry sump system other then the chance of the belt breaking or coming off of a normal set up. I really like that it uses a "stock type" pump with no belt to break.
Old Mar 30, 2014 | 05:41 PM
blue-03-ss's Avatar
anyone have any idea if this will work?
Old Mar 30, 2014 | 05:48 PM
Darkman's Avatar
https://ls1tech.com/forums/conversio...y-oil-pan.html
https://ls1tech.com/forums/generatio...p-98-vert.html
https://ls1tech.com/forums/generatio...-pump-ls1.html
https://ls1tech.com/forums/conversio...-oil-pans.html
http://www.hotrod.com/howto/hrdp_070.../photo_05.html
http://www.grrrr8.net/crazypaul/GEN%...20Hardware.pdf
http://www.hotrodlane.cc/Oil%20pans/...asurments.html
Old Mar 30, 2014 | 10:39 PM
Linda Williams's Avatar
This is not just a "remove the oil pan" job. In order to access the aforementioned bolts, AND in order to remove the oil pan, I had to remove: 1) 3 parts of the transmission covering and support; 2) disconnect the gear shifter (at the transmission, of course); and 3) remove a thin metal transmission shield.
Old Mar 30, 2014 | 11:42 PM
blue-03-ss's Avatar
the motor is setting on the ground waiting to be rebuild and installed into a foxbody mustang. So I'm not just changing the pan with will be a build with a goal of 1000WHP.
Old Apr 1, 2014 | 07:35 PM
S10xGN's Avatar
The biggest change I see is needing the LS7 crank snout (+1") to use the internal oil pump...
