LS1 Spring retainer
Old Apr 14, 2014 | 09:49 AM
  #61
Justhereforinfo's Avatar
If those are 241 heads, you might wanna consider buying a new head, rather than having it repaired.
Old Apr 14, 2014 | 10:48 AM
  #62
fastlane02ss's Avatar
It is a 241 head.Does anyone know what the GM part number is for the intake valve guide?
Old Apr 14, 2014 | 11:21 AM
  #63
GMC5.3's Avatar
Sorry to hear, you can catch a break at all. Try and keep your head up, mind if I ask How you pulled the pan and about how long it took you?
Old Apr 14, 2014 | 11:46 AM
  #64
I had 2 friends helping so it went fairly quick,probably took us about 2 hours or so.I just used a floor jack handle and layed it across the top of the strut towers and put a chain around it and secured it to the engine to keep it up,then just worked the jack on the crossmember under the engine.Take out the motor mount bolts,sway bar,etc....all the stuff to be able to let you drop that crossmember down.I just got it loose enough where I could let the jack down on the crossmember to get enough to slide the pan out.A buddy was kinda directing me on what to do,I had never done it before and he had.I was just taking off what he said to take off,I dont really remember all what we loosened,We were in a bit of a hurry.Alternator came off also.I know this isnt alot of help,just going off what I remember.It doesnt have to drop much and it will slide right out though.
Old Apr 14, 2014 | 11:54 AM
  #65
GMC5.3's Avatar
Well your totally right, I just got back from starting the car and nothing but drips, I waited 24 hrs for that rtv to sit and it didn't help me out at all. I appreciate the help, just need to figure out how to do this at my apartment complex
Old Apr 14, 2014 | 12:10 PM
  #66
Dang I hate it you have to change the gasket out.Hopefully you will have help,it makes that job alot easier.I think the gasket ran around $50-$60 somewhere around that.Good luck with it though.Im dropping my cylinder head off tomorrow to get done,hopefully ill be up and running friday or saturday.
Old Apr 16, 2014 | 06:48 AM
  #67
GMC5.3's Avatar
It's a race then, let's see who gets their cars running first, I'm going on vacation till sat so I can't work on it till next week also
Old Apr 16, 2014 | 07:33 AM
  #68
I got the cylinder head back yesterday,so I should be going back together starting tomorrow more than likely.
Old Apr 18, 2014 | 07:26 PM
  #69
GMC5.3's Avatar
You might beat me , I should be back to work on my camaro tomorrow to hopefully get tuned Sunday
Old Apr 21, 2014 | 06:53 AM
  #70
Im up and running now,drove it to work today just cruising to make sure everything is good before I drop it off to be tuned.Everything seems to be good though,nothing is broken!
Old Apr 22, 2014 | 02:34 PM
  #71
GMC5.3's Avatar
I'm good as well, had the car tuned on Sunday. Still have a stupid leak, thinking it's the rear main seal now, not as bad as before though
