Stroker motor compression test... 210 - 250 psi
1: 225
2: 250
3: 240
4: 245
5: 240
6: 250
7: 210
8: 215
The lowest number is 16% less than the highest, and the lowest value is 10% less than the average value of 234 psi.
Is this normal? any thoughts?
Cyl..Comp..PTW......Ring Gaps
1....225...0.0040"...0.020-0.024"
2....250...0.0046"...0.019-0.025"
3....240...0.0039"...0.018-0.024"
4....245...0.0031"...0.019-0.026"
5....240...0.0040"...0.020-0.024"
6....250...0.0034"...0.018-0.024"
7....210...0.0041"...0.019-0.023"
8....215...0.0048"...0.019-0.022"
Note: the cylinder bore measurements were taken without torque plates.
Whenever a circle track customer of mine overheats his engine the ring seal goes to complete ****. It just takes all the tension out of them and upon tear down I can literally remove the compression rings and twist them 90 degrees without them breaking and they'll stay that way.....TOAST !!!!
Anyone know of a reference for "normal" cylinder pressures on high performance engines? My SCR is 11.35 and DCR is 8.5.
Thanks
There are so many factors that can change psi numbers. Hot; Cold; Oil in the cylinders; Fuel on the cylinder walls; Rings rotated and lined up....etc.
I'm sure the tune is spot on and I know fuel injection and coil on plug ignition are top notch for preventing detonation but old school mouse motors run into issues with octane at between 160-180 psi and knock sensors should work but it's difficult to hear or see the effects untill teardown.
A lighter vehicle with decent gears does help and so does old school non-reformulated gas. 220 is still making pretty stout POP in the holes !!!!
