Milled 317 with MS3 cam question
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
Lonnie
Lonnie
Lonnie
You send the heads for porting and welding the chambers to desired cc. So valve drop remains unchanged but chamber gets smaller and thus increases compression. AI does a really nice job at that.
I experienced that fist hand on a set of heads I had on for a supercharged setup. When I went NA, I needed smaller chambers. Your end product are aset of cnc ported heads with small chambers and all the benefits of the 243/799 port design.
