BTR Stage 4 vs Tsunami
Old May 12, 2014 | 02:02 PM
badtransam97's Avatar
What heads are you using? Anyone using a 5.3L head with either of these?
Old May 12, 2014 | 02:20 PM
HCI2000SS's Avatar
I use 5.3 heads with a cam very similar to the MS3 and MS4 and it works great. I can't see it making much difference with the two cams you're looking at
Old May 12, 2014 | 10:23 PM
JakeFusion's Avatar
Super Hulk Smash
Originally Posted by badtransam97
Thanks guys! Guess I'll stick with the tsunami I have. Any idea why to stick with unported 243's vs the cnc'd?
Ported 243s usually have pretty good sized ports 225+cc which, when combined with a cam with lots of overlap and later IVC, can be somewhat of a dog down-low in an M6. At least that's my guess. Compression and gearing helps.
Old May 12, 2014 | 11:06 PM
Would you think a 5.3 head would be better then? Just don't want to spend the money on a set if heads that are not optimal.
Old May 13, 2014 | 08:02 AM
JakeFusion's Avatar
Super Hulk Smash
Most 5.3s are opened up nearly as far as the LS6s but don't flow as well. Their main benefit is a slightly smaller chamber to begin with, so you get a slight compression bump. I'd stick with the ported LS6s. They will never have the velocity of AFR 205s, for example, but can make power.
Old May 13, 2014 | 08:52 PM
bears416's Avatar
Talk to Brian he will tell you how the stage IV makes great down low torque. Its wat I went with and will be installing with a monster stage 3 next month. I expect to see around 420 on stock 806 heads. With 243s u shud be around 450-460.
Old May 13, 2014 | 11:33 PM
bears416 did he tell you to run an unported head as well?
Old May 14, 2014 | 05:45 AM
bears416's Avatar
He did beat around the bush in a round about way to that. He said I may lose power with some ported heads that were not ported rite. Unported 243s wud put u at.450ish HP in perfect world. I have 806s I'm hoping for 410-430 there people getting 400 on the stage 1
Old Jul 15, 2014 | 07:32 PM
Gotit4cheap16's Avatar
Getting the btr s4 cam this weekend and sold my torquer v3. Cant wait.
Old Jul 16, 2014 | 09:32 AM
cuisinartvette's Avatar
Unless your cam is grossly mismatched to start with changing to something a few degrees +- wont make a damn bit of difference
Youll always get someone insisting you need a custom cam because they can make a quick buck off ya....or thats what they bought-which is usually some off the shelf piece anyways.
Learn to perfect your driving; play with the chassis etc optimize what ya got then go hunting for more. At that point youll probably build bigger ci all together
Old Jul 16, 2014 | 10:18 AM
Rise of the Phoenix's Avatar
I'm sure you'll be really happy with it. Just make sure you get a tuner that can give you a rock solid and safe tune.
