Help! Rebuilt ls1 won't start
Before you go that way (maybe you have no way of checking this), I would check the injectors with a noid light, and verify that they are "firing". Firing, and the actual opening, are two different things. Depending on how long the injectors had been unused, may cause them to gum up, so even though they are "firing", there may be little or no gas flowing through them.
Your scanner is not showing engine RPM when cranking. If this is the case, the computer does not know the engine is turning so it will not fire the injectors or the plugs.
Did this mean that the BCM module is unplugged?
VATS needs either to be disabled, or, the VATS signal needs to be constant, like a VATS module.
Maybe the later F-bodies operate using a different system?
