clanking after intake swap?!?!!?
Old Jun 11, 2014 | 09:40 AM
RebelMan666's Avatar
Default clanking after intake swap?!?!!?
I have a 2000 ws6. I did an ls6 intake swap. After the install it started right up no problem. Then i heard a clanking noise like something metal was bouncing around in the heads. I am almost positive i did not drop anything metal into it. The was alot of debris from getting the old intake off that probably fell in.. maybe even a nut shell from a squirrel SMH... i never set any tools Down near the engine. I dont have full power on accelerarion. My check engine light is on and when i gave it gas in 3rd gear the check engine light started blinking. I followed the ls1howto guide to do the swap and followed the bolt tightening pattern. Just don't know what it could be without pulling everything apart again..
Old Jun 11, 2014 | 09:54 AM
mattster03's Avatar
Yikes... I'll bet something did fall in there like a small nut or screw
Old Jun 11, 2014 | 10:01 AM
So now what?!? I have to drop the motor??
Old Jun 11, 2014 | 04:56 PM
Is it easier to just drop the motor? Can you pull the heads without? Do i need to remove the heads in order too see if anything fell in during the intake swap. What needs done?
Old Jun 11, 2014 | 05:08 PM
Zmg00camaross's Avatar
Remove the intake and inspect. Also can to leak down test.
Old Jun 12, 2014 | 06:59 AM
Old Geezer's Avatar
What's stuck on the end of a plug?
End gone, crushed, etc?
Old Jun 12, 2014 | 11:54 AM
RockinWs6's Avatar
Well if you scan it you can find which cylinder is miss firing, pull the spark plug and see if something hit it.
Old Jun 14, 2014 | 09:12 AM
Ok. So after reinspecting the first install there were two injector sensors that were not pushed in all the way that would explain the loss in power and the check engine light. (Dumba@$$ rookie mistake...) Would that cause rattling and engine noise as well?
Old Jun 14, 2014 | 10:34 AM
Bump for anyone. Have the intake off and everything apart right now. Looked down the cylinders and they are clean. Would a bad gasket seal and two unplugged sensors cause any noise?
Old Jun 14, 2014 | 01:12 PM
Possible it missing bad was makeing a funny noise. Don't know unless I heard it. But that be a heavy miss without 2 cylinders lol.
Old Jun 16, 2014 | 03:02 AM
Bought new gaskets, cleaned everything up spotless, buttoned it back up and everything went back to normal. No more noise and gained full power back. It was a good life and learn lesson. Won't be taking any short cuts in the future lol
Old Jun 16, 2014 | 04:36 AM
poughcujiayi's Avatar
Old Jun 16, 2014 | 09:16 AM
