Advise with Timing Chain Damper
Old Jun 25, 2014 | 12:50 PM
Dale002's Avatar
Default Advise with Timing Chain Damper
Ok I changed the timing set on my 98 formula LS1 engine. I want to install a chain Damper, but don't know which type to purchase. The block is already drilled for one. Any advise would be appreciated.
Old Jun 25, 2014 | 12:56 PM
Always2Slow's Avatar
Katech had one that worked exclusively for the ls1 engine, but I would imagine it would be harder to find these days. You can try contacting them. I have seen people modify ls2 dampers and of the like to work on the ls1 block by re drilling holes or modifying the damper itself.
Old Jun 25, 2014 | 01:17 PM
5.0 LsX's Avatar
I have a slightly used one laying around somewhere, as long as I can find it in my garage $40 shipped
Old Jun 25, 2014 | 01:49 PM
01ssreda4's Avatar
Since when are 98 LS1s drilled for dampers? It would help to know what engine you were talking about.
Old Jun 25, 2014 | 04:15 PM
Brief Encounter's Avatar
My 98 was drilled as well.
I believe most if not all 97-98 blocks had the holes drilled.
Old Jun 25, 2014 | 08:24 PM
Dale002's Avatar
I'm talking about an LS1 out of a 98 firebird formula. Are there any other for that year on a formula?
Old Jun 25, 2014 | 08:34 PM
JakeFusion's Avatar
Super Hulk Smash
I believe that's true. The 97 Vettes had the provision drilled and perhaps the 98s. But it was again added in the LS6 motors and the later LS1s (01-02). My 02 LS1 block was drilled. I used the Katech Damper. It's expensive as **** tho.
Here is my Katech Damper installed:
Old Jun 25, 2014 | 08:47 PM
Pharcyde50's Avatar
I used the ls2 damper and the trickflow kit.
Old Jun 25, 2014 | 10:33 PM
LLLosingit's Avatar
This is what I plan on using and probably what Pharcyde50 was referring to. http://www.summitracing.com/parts/tf...5600/overview/
Old Jun 25, 2014 | 10:35 PM
01ssreda4's Avatar
There are two bolt spacings, one wider, one narrower, for those reading.
Old Jun 25, 2014 | 10:40 PM
chevybayboy's Avatar
Mine Was also predrilled for it I installed mine bought from a member on here works great
Old Jun 25, 2014 | 11:15 PM
That bolts right up assuming they would have to drill and tap the holes? No interference whatsoever?
Old Jun 26, 2014 | 01:53 AM
ls1 1990 VN's Avatar
[QUOTE=JakeFusion;18289487]I believe that's true. The 97 Vettes had the provision drilled and perhaps the 98s. But it was again added in the LS6 motors and the later LS1s (01-02). My 02 LS1 block was drilled. I used the Katech Damper. It's expensive as **** tho.
My 97-2000 Vette engine isn't drilled! I used the Trickflow kit & LS2 damper.
Old Jun 26, 2014 | 02:09 AM
cluby's Avatar
I am looking at buying a ls1 5.7. it has piston slap when it cold. now would this be a good motor to rebuild? or would the bores be stuffed? cheers
Old Jun 26, 2014 | 03:50 AM
kozeehezheya's Avatar
Old Jun 26, 2014 | 04:27 AM
Exidous's Avatar
Your two post count are the same post in two different locations. Good start.
The trick flow damper is the best route $ wise. My block was already drilled as well but $100 for a damper is just dumb.
Old Jun 26, 2014 | 07:07 AM
vettenuts's Avatar
If your block is pre-drilled pick up the original tan GMPP damper. The used one above is a good deal.
Old Jun 26, 2014 | 07:18 AM
v8pwr's Avatar
This is correct. GM used to have a damper available then they stopped. Later they created a newer design commonly seen on the ls2 then changed again with the ls3. The first and second design are similar but different bolt hole spacing. Once the original was canceled people would drill ls1 blocks for the new ls2 design damper. The ls2 & ls3 share the same bolt spacing but are a different design. A lot of builders ditch the ls3 spring loaded in favor for the ls2 as it's more durable and shares the same bolt spacing. The Trick Flow setup from Summit is to retrofit blocks that did not have the holes drilled and uses the cam retainer plate.
Old Jun 26, 2014 | 08:22 AM
Dale002's Avatar
Will probably go with the set up from summit, since is half the cost of the original LS1 damper
Old Jun 26, 2014 | 05:35 PM
JakeFusion's Avatar
Super Hulk Smash
If you aren't pre-drilled and don't want to spend crazy cash, the Trickflow unit works well.
