Patriot head questions
So heres the problem. I was told they are 50cc but that seems unlikely as they came as 59cc and that seems like a ton of material to remove/add to a head.
So heres the deal the cam I have is a .612 lift cam and if these are 59cc heads how well do you guys think it will work and will I have any clearance issues? I know that will put my compression near 11.3. I also know if they are actually 50cc then that pretty much means they will have to stick with the other engine. Im really not finding a ton of info on these heads especially with patriot out of business. Luckily I picked them up cheap and in great shape.
So whats everyones thoughts?
Have some one CC them or buy a tool and do it your self to be sure.
The heads are definitely ported can tell that much. From what I can tell from patriot listing the heads should have .650 springs on them but looking at the heads I dont know. Guess we will end up finding out at the machine shop.
And yeah the springs im a bit nervous about because I read the stage 1 heads only came with springs that held upto .600
Bama thank youi I will be getting in touch with them.
