Engine noise?
Old Jul 16, 2014 | 08:42 PM
Firecat700RR's Avatar
Default Engine noise?
My 99 ls1 is making a noise at around 2k gets quiter when warm but still there. Lookin for opinions loose rocker bent pushrod? Noise was never like this before.
Old Jul 16, 2014 | 08:53 PM
Another video noise only seems to be comin from driver side?
Old Jul 20, 2014 | 02:22 PM
Nobody can help? This noise is driving me nuts. Pulled valve covers checked pushrods and springs all looked good. Anyone have any other ideas? Thanks
Old Jul 20, 2014 | 03:25 PM
poltergeist 02's Avatar
Have you pulled the valve covers yet to inspect the rockers and pushrods yet?
Old Jul 20, 2014 | 03:48 PM
Iam Broke's Avatar
If the pushrods & springs are all ok, it could be a lifter collapsed, rod bearing, wrist pin or main bearing. Hard to tell from the vid, sorry.
No misfire or other DTC's?
Run a compression and leakdown test to rule out pistons, rings & valves.
Old Jul 20, 2014 | 04:24 PM
Yeah I'm in the process of checking passanger side right now. Car has good oil pressure driver pushrods were all straight and springs looked good. Springs I just gave a visual. The noise is def coming from top end though. What should comp be on the gauge and they all should be close I know. Doesn't sound like a rod it gets quieter when warm also but not gone.
Old Jul 20, 2014 | 04:27 PM
No misfire or dtc's also what would cause a lifter to collapse outta the blue? And wouldn't that cause a skip or misfire?
Old Jul 20, 2014 | 09:39 PM
Just bottoned back up pushrods and rockers nothing was bent or loose. Changed oil and filter to pennzoil synthetic 5-30 from mobil1 0-40. That seemed to quite it down alil. Took car out ran it threw the gears a few times everything seems great just still got that ticking sound coming from lifters under the intake it sounds like.Guess I'll just run it don't wanna pull heads to change lifters out when car has good oil pressure and runs good.
Old Jul 21, 2014 | 01:59 PM
Mike454SS's Avatar
Are the knock sensors picking up the noise?
Are your fuel trims suddenly out of whack?
I would not run with a lifter problem...could hurt the cam, put metal in the bottom end and then you have scrap instead of an engine.
It's a lot of work pulling the heads to replace a bad lifter...but you gotta do what you gotta do.
Old Jul 21, 2014 | 02:01 PM
Mike454SS's Avatar
...and for what it's worth man, it's pretty hard to tell what's going on from a video on the computer...I don't know where the sound is coming from, and I'm sure my speakers sound different than yours do.
Old Jul 22, 2014 | 06:31 PM
Thanks mike. Wanna hear something funny but I switched to pennzoil synthetic 5-30 and the noise has considerable quited down about as quite as it was. When I was checking pushrods inside of motor had a lot of brown tarnish on everything. I wonder if the lifters picked up some junk in them? Or I read a leaking o-ring on the pickup tube can cause this? I would think that would screw with oil pressure wouldn't it? But anyhow a lot quieter right now.
