need Drag cam for 383 stroker
I want a good NA and N20 cam if that is possible, plan on running a DP to get into the 9's but want 10.50's or better NA also, which actually I am pretty sure I can get out of my current setup. I just don't want this reverse split for N20 and am sure I can do better with a bigger cam NA.
currently have a 90mm LSX, RMS heads, 11.0:1 compression, 1 3/4 dynatechs running a 10" extension at the track.
also want to push over 500rwhp... should be about 495 now, but no new dyno numbers with the 90mm lsx.
thinking of a TRex size range but about 6 degrees more duration for the extra cubes, but am obviously looking for suggestions
about 2 months ago I put down 485rwhp/475rwtq with a 78mm LSX
ran a 10.94 w/ 1.54 60' in 2500 da last week, only got one good run and tq arm mount broke
and car has gone 10.83 w/ a 1.60 60' w/ LS6 intake in 1000 DA.
futural recommended this a few months ago...
238/242 113lsa
I'd be listening to Futral. They've been doing some good things here latley. AP engineering is also good to deal with, but I think the cam this guy is talking about was for there 408 motors. Trending Topics
Vince
