Can i run 11.50 or better cam only
Your goal can be done if you have an ls1 or an ls2. Will be much easier with the ls2. This is what it's going to take to do it though. You need to get a good tire under the car 10" 28" tall tire. It can be done with the right set of rims and drag bags. Your going to want at least 4.11 gears. I would port the ls2 intake and throttle body. You could then port the heads and get a competition valve job done. Stick to a medium sized cam like a 228 232 on a 111 lsa or the like. Grab a 4000 stall with a good tranny cooler and learn how to drive. This can be done.
My only mods so far are 1 7/8 headers in to a 3" system and a 4k converter. Ive run a best of a 13.4 at 100mph.
Not going happen
Big cam and nice heads still won't make it happen unless you get some mineshaft air and get it to leave really hard, like halfshaft rear diff breaking hard.
