Need updated PTV specs
Old Aug 29, 2014 | 05:09 PM
BrainFreezE's Avatar
Default Need updated PTV specs
So I have .020 milled 243 heads. With ms3 cam. I'm at about 80-85 close to 90 PTV clearance. Do I need to fly cut pistons? What is the lowest someone has run clearance wise. It's gonna be a daily with moderate drag racing.
I've read people running less without problems. Thanks.
Old Aug 29, 2014 | 05:24 PM
speedtigger's Avatar
Old School Heavy
What are the exact specs on that cam and how did you measure?
Old Aug 29, 2014 | 05:27 PM
237/242 603/610 112. Measured using clay.
Old Aug 29, 2014 | 06:14 PM
svede1212's Avatar
.080 should be fine. Generally .080 intake and .060 exhaust are considered to be safe.
Old Aug 29, 2014 | 06:35 PM
Old School Heavy
What is the intake centerline on that cam?
Old Aug 29, 2014 | 07:11 PM
not sure going to have to look at the spec sheet when I get a chance.
Old Aug 30, 2014 | 08:13 AM
01ssreda4's Avatar
I've been running 90/70 for a couple of years now with no issues. Valve control is critical, and stay off the limiter if at all possible.
Old Aug 30, 2014 | 09:23 AM
lol so no power shifting. I think I can live with that.
Old Aug 30, 2014 | 11:56 AM
Old School Heavy
A lot of guys run a lot less clearance than that. The T-Rex cam has about half of that LOL.
Old Aug 30, 2014 | 02:32 PM
even if I'm spraying a 100 shot I should be fine?
Old Aug 30, 2014 | 02:56 PM
Old School Heavy
Hey, I never said anything was fine LOL. Just noting that they do it.
PtoV is not an issue with running nitrous. Unless you have no rev limiter. LOL
