Rocker arm to valve spring retainer interference
As far as I can tell I have the following options:
1. Shim the pedestal to raise the rocker and clear the spring retainer. I don't know if this is a valid option strengthwise. I also know I would have to check the wipe pattern and use longer pushrods if I do this.
2. Get different springs and retainers (Comp cams has one with a 1.320" dia and 1.835" installed height that is made to go with the cam. I don't know if this would give me the clearance I need or not with the stock rockers. I know I would need to shim the springs .115" and also I would need spring locators due to the smaller size.
3. Get new rocker arms like the Yella Terra that have adjustable mounts. Thsi seems pretty straightforward, but I still don't know if they will clear the 1.550" springs.
Any help or ideas you guy can give is appreciated. If you have negative comments about my choice of heads, please move on.
Here are your spring specs: 1.550": 200 lbs. @ 1.900", 480 lbs. @ 1.200", coil bind @ 1.150", max lift MAX LIFT @ .700"
Those spring rates require quality aftermarket rocker arms.
If you're going to use a solid roller cam, update the rest of the parts to match. If you're using hydrailic lifters, change the springs to match, and then shim the rocker arms.
.675" max lift
159 lbs on the seat
448 lbs at .675" lift
with my cam
420lbs@ .610" lift
423lbs @ .617"lift
comparing to my current springs
200 lbs on the seat
480 lbs at .700" lift
with my cam
444lbs@ .610 lift
447lb@ .617 lift
Does 20-25lbs really make a difference between hydraulic and solid?
I will change the springs if I have to, but I really don't see the need at this point unless it gives me the rocker clearance I need.
When you say change the spring and shim the rocker arms, how would you shim the rocker arms? Do you mean an aftermarket arm or the OEM?
If you intend to use, the open spring pressure isn't what concerns me. It's the seat pressure. You'll need to upgrade to a lifter that can withstand that without bleeding down. Morel or Johnson would be my pick there.
Sounds like you have the wrong parts and are trying to fix it with stuff that will work but is not the best choice of parts
No way would I trust those rockers with anywhere near that much spring.
Custom PAC spring kit would be you best option. Depending on your valve length you may need shorter valves or buy a set of $1500 shaft rockers.
Tim
You should consider replacing the valves with shorter stems. I'm not sure what clearances are with the YT rockers, but after you shim them up for the longer valves, you might have trouble with valve cover interferance. And you'll need longer custom made push rods.
You might consider selling what you have, and starting over. In the long run it sometimes works out cheaper and easier that way.
