400whp+ weekend warrior build
Old Sep 29, 2014 | 05:32 PM
V8z33's Avatar
Default 400whp+ weekend warrior build
Hey guys, I'm new to the v8 scene coming from the import scene. Im doing a stock lq9 swap into a nissan 350z… Im running a gto T56 and I'm looking for a solid cam that could make power from 3000-7000rpm since i plan to DD and do road racing during the weekend. I DO NOT want to flycut the pistons. Im looking for plug and and play… I'm thinking the torquer v2 or a custom cam with the following specs 233/237 .585/.589. lsa 113+4. Mid range and top end mean more to me than power down low x<3000rpm. Any suggestions??
Cliff notes
stock lq9
t56
1-7/8 LT headers from my SIKKY swap Kit (3.5in outlet)
LS6 intake
36lb injectors
3in true dual exhaust
spec 3+ clutch
.620 lift valve springs
psi wire harness
custom tune
WHAT CAM?
Old Sep 29, 2014 | 06:27 PM
HCI2000SS's Avatar
So this will be stock heads and compression LQ9?
Old Sep 29, 2014 | 07:58 PM
V8z33's Avatar
Yessir…. gonna buy GOOD heads when i have the cash
Old Oct 4, 2014 | 03:08 PM
Thee Antic's Avatar
Buy my 228r....
Old Oct 4, 2014 | 10:26 PM
1nasty86's Avatar
Turd Gen Guy
I'd raise thd compression some with whatever heads you plan on buying.... and as for cams there are a solid number of grinds out there.... Brian tooley or Martin@tick can set you on the right path cam wise
Old Oct 7, 2014 | 09:57 AM
Sales@Tick's Avatar
Race weight and rear gear ratio?
Old Oct 7, 2014 | 10:33 AM
kinglt-1's Avatar
For a stock LQ9 I would keep the intake duration in the low 230's for a street car. Weight and gearing will also play a big factor in deciding. Steeper gear and lighter weight will allow you to go larger on the cam and still maintain street manners.
Old Oct 7, 2014 | 03:49 PM
poltergeist 02's Avatar
If you are looking to dd it and road race it, I would chose a cam profile with an endurance type lobe.
