Budget buget 6 litre build
That cam is pretty mild. Op what exactly are you looking for plenty of cams are reliable daily drivers so by telling us what your hp and driveability goals re we can better help. I can tell you that those springs are fine with that cam but after the 918 failure a few years back I personally like pac 1218's or my persoanl favorite and what I run is psi1511's they are the only beehive without a single failure documented and are what gm uses in their crate motors.
Beehives are commonly rated to .625 lift and even to .650 duals ahve their place in bigger cams where the ramp rates are hard to control but not here
this... lol like relating lift to stress.
3.73 and 31" tire on a truck is 1981rpm at 70mph.
4.10 and 31" tire on a truck is 2177rpm at 70mph.
Tire size matters as well as the weight of the vehicle, truck needs a lot more gear for the same cam due to weight and tire size effect on gearing.
The 3.46 gearing mentioned suggests this is not a typical LS vehicle so it is only reasonable to ask for more detail.
https://ls1tech.com/forums/dynamometer-results-comparisons/1213394-baby-eps-cam-lays-down-430rwhp-415rwtq-track-results.html
https://ls1tech.com/forums/dynamomet...k-results.html
