cleaning pistons
Old Nov 8, 2014 | 09:01 PM
SCott5's Avatar
Default cleaning pistons
What you guys using to clean the top of pistons? Got a set that I wanna clean up before I put back in
Old Nov 8, 2014 | 09:07 PM
11SECSS's Avatar
I have used some scotch brite pads and brake clean.
Old Nov 8, 2014 | 09:21 PM
madmike9396's Avatar
Good ol fashioned Elbow Grease Scott ! LOL
Old Nov 9, 2014 | 08:29 AM
slogo's Avatar
I have found a purple version of simple green at Home Depot, I was very surprised how
well it worked, I cleaned entire block so far then quickly wiped down cylinder walls with a WD40 soaked lint free rag, rinsed with water, wiped down cylinder walls again with same
rag, then used compressed air to dry. Parts looks good
Old Nov 9, 2014 | 08:35 AM
KCS's Avatar
KCS
Moderator
Wire wheel
Old Nov 9, 2014 | 09:10 AM
.boB's Avatar
Simple Green for the grease and oil part. And then a soft wire wheel in a drill motor for the crusty stuff. Easy Off oven cleaner works pretty good, too. But it can be pretty rough on the hands.
Old Nov 9, 2014 | 09:19 AM
96capricemgr's Avatar
Careful using degreasers on aluminum because most will etch aluminum given some time, like say the puddle that gets down into the ring lands and not flushed out when you are done cleaning the crown.
Old Nov 9, 2014 | 09:31 AM
SCott5's Avatar
Yea, that's why I figured I would ask, don't want to do any damage to the piston. I'm going to go grab some purple power/simple green and soft bristle wheel for my drill. Thanks guys
Old Nov 9, 2014 | 09:53 AM
Simple Green and Purple Power are degreasers. Something like Seafoam has naphtha which is a good carbon solvent, and doesn't have anything to hurt aluminum.
I know folks are going to claim I am wrong about the degreasers but it takes time to do the damage. Doubt you will hurt the crown because you will wipe it off, the places it reaches that you miss are the concern.
Old Nov 9, 2014 | 09:57 AM
SCott5's Avatar
Would it be fine if I sprayed wd40 down in the ringlands then blow out with air?
Old Nov 9, 2014 | 07:35 PM
MuhThugga's Avatar
Originally Posted by KCS
Wire wheel
Yep. A soft wire wheel.
There isn't any aluminum in the cylinders.
Old Nov 9, 2014 | 07:58 PM
How about the pistons he is trying to clean............
Old Nov 9, 2014 | 08:02 PM
speedtigger's Avatar
Old School Heavy
X3 on the wire wheel.
Old Nov 9, 2014 | 09:00 PM
Why worry about a little carbon on the crowns anyway?
Old Nov 10, 2014 | 09:25 AM
MuhThugga's Avatar
Aluminum alloy =/= aluminum
Old Nov 10, 2014 | 02:35 PM
Old Geezer's Avatar
Lightbulb Time 4 u to...
pass the bong to your buddy.
Old Nov 10, 2014 | 04:03 PM
LS1nut346's Avatar
Brake Kleen
Old Nov 10, 2014 | 04:21 PM
MuhThugga's Avatar
Let me troll in peace, plz.
Old Nov 10, 2014 | 08:10 PM
GiggleJuiced_SS's Avatar
X4 wire wheel. Brake clean. Blow it off with air compressor. Done. I do this on valves too.
Old Nov 12, 2014 | 04:27 PM
LS1nut346's Avatar
I don't. the crowns don't have to be perfect.
