Johnson SLR link bar lifter questions (PLEASE HELP)
Old Nov 15, 2014 | 12:25 PM
00ssmg's Avatar
Default Johnson SLR link bar lifter questions (PLEASE HELP)
So i just purchased and received my new set of Johnson link bars for my LS1. It was a very difficult decision to make as everyone you talk to has a different opinion on Lifter choices. So i decided to spend the extra coin with Johnson's rather than the other options. They were very helpful on the phone and answered all of my questions better than anyone else could. The body of the lifter and link bar set up are nice quality pieces. The only concern i have upon inspection of the new set up, is that the rollers seem very rough to roll and seems like there is a metal to metal contact. Don't get me wrong they roll okay and its not like there are shavings rolling out of the bottom but they are definitely not as smooth as the LS7's i have that are also new (didnt do my research first). I guess my question is has anyone else seen this or experienced it? Is it that they need to be cleaned and soaked in oil? I just expected a nicer quality roll for the $600, and they dont even seem to roll as nice as the LS7's i have? I'll contact them on Monday but wanted some other opinions as well. thanks
Old Nov 15, 2014 | 02:39 PM
KCS's Avatar
KCS
Moderator
I've never used Johnson lifters, but I've used other aftermarket brands than had an anticorrosion grease in them that had to be cleaned out before use. It should say something in the instructions about cleaning before use.
Old Nov 15, 2014 | 04:17 PM
svede1212's Avatar
With the pressure on the roller from the springs there should be really no effective difference between that and your LS7s. I wouldn't sweat it at all.
Old Nov 15, 2014 | 05:34 PM
Jase01's Avatar
I've got a set to go in my engine and all of the rollers spun freely except one which felt a bit rough, not metallic but sort of lumpy and tight to spin.
I emailed Tony Mamo who I bought them from and he suggested it might just be a bit of hardened assembly lube and to maybe soak it in some mineral spirits. I tried squirting a little bit of oil into the roller and blew some compressed air into it which seems to have freed it up pretty well.
The box mine came in had absolutely no supporting paperwork whatsoever but I emailed Johnson themselves for some info originally before I found the dodgy roller and Randy Vroomen got back to me really quickly and is pretty helpful, I hope this helps you.
Best wishes,
Jason.
Old Nov 15, 2014 | 08:04 PM
00ssmg's Avatar
Thank you for the help guys. its hard to describe the roller. the above could be a good description as well. I will clean them up with some parts cleaner and put them in some oil and check the. I dont plan to build this thing for about another 3 months so the oil will help protect them in storage anyways. thanks
Old Nov 16, 2014 | 04:28 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I've had this issue with a number of different brands of lifters. Most of the situations I have encountered with a roller that didn't feel smooth was due to assembly lube issues.
I actually have a cheap Walmart crock pot that I "cook" all my lifters in prior to a build....LOL I use a thin synthetic oil and bring the temp to 200 or so (I measure using a heat gun). Let them sit in the hot oil bath for hours (you only need to bring it to temp and turn off the burner.....its amazing how long it takes to cool off a pot of hot oil and a bunch of metal components inside!)
When its still warm (comfortable enough to handle)....I remove a pair of lifters at a time and check out the wheel action....its usually a whole lot better than when they were cold right out of the box. You may find that a few still feel sticky.....just spin them a bit in your hand and it should smooth right out. If you go thru the trouble of doing all of this and still have an issues use the parts washer and a blow gun and re-soak in oil after you blow it clean from the parts washer spinning the roller as you do it. If that doesn't cure it get with the manufacturer and get a new lifter pair sent to you. I would not install a roller lifter that didn't feel smooth if you prepped it the way I just described....that would indicate an issue of some kind in the assembly.
I've used alot of different manufacturers lifters and some roll smoother than others right out of the box even when comparing the same manufacturer's parts. The method I just described takes a little extra time but its worth it.....it also helps bleed any air out as well for less bleed down on fire up and guarantees the axle wheel is covered in fresh oil.
Hope this helps....
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Nov 18, 2014 | 12:28 AM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
VERY COOL TIP!
( no pun intended ) LOL
Old Nov 18, 2014 | 11:09 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Tips like this are what keep me coming back to this site. Thanks for that, Tony.
Old Nov 18, 2014 | 11:51 AM
RonSSNova's Avatar
We will all be looking for used crock pots at garage sales now!
Ron
Old Nov 18, 2014 | 06:09 PM
BlwnLs1GTO's Avatar
My Lunati Link bar lifters had a couple that did this same thing. I know what you're trying to describe. You can "Feel" the roughness when rolling it over your fingers.
I might have to go to Walmart tonight lol.
Old Nov 18, 2014 | 06:57 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Who needs a crock pot, just use a regular steel pan, it's not like it's porous, just use soap and water after and wash the pan. I agree, great tip for us all.
Old Nov 18, 2014 | 09:42 PM
dr_whigham's Avatar
The Scammer Hammer
I'm guessing bc you can put it in the garage and regulate the temp. I mean they're cheap, like 20 bucks, and then no need to use the oven and smell the house up with motor oil...
Old Nov 18, 2014 | 09:49 PM
LS1Tech Sponsor
Mmmmmmm....I smell some lifters soaking.....LOL
Glad to help guys
(A little bit of Mamofied **** engine building tips )
It does stink if you do it on the stove....wait for the wife or GF to be gone for the day!
__________________
Old Nov 18, 2014 | 11:04 PM
JakeFusion's Avatar
Super Hulk Smash
I cleaned all of mine thoroughly with B-12, let them dry, and then tested the rollers. All worked as they should. I also tested the link bars and made sure they were all working without any hitch.
And then I put Joe Gibbs assembly lube on the wheels and bodies. Everything went together without a hitch.
Try cleaning them out and see. That was one thing I knew had to be done. I sprayed B-12 everywhere to dissolve any oil or blow out any grit. Grit is what kills lifters.
Old Nov 19, 2014 | 06:41 AM
UNDER PRESSURE MOD
The wifey loves the smell of some good 5-30 cooking on the stove. lol.
Old Nov 19, 2014 | 07:28 AM
dr_whigham's Avatar
The Scammer Hammer
Lol. Just wait till she sees that you've taken it upon yourself, sans permission, to have front, rear, and valve covers in the dishwasher.
Old Nov 19, 2014 | 08:41 AM
LS1nut346's Avatar
Definitely a good tip. I may be getting some johnson lifters so I'll keep this in mind.
Old Nov 19, 2014 | 09:36 AM
MMorgan9812's Avatar
That's why you wait till she is out of town for the weekend
Old Nov 19, 2014 | 09:53 AM
UNDER PRESSURE MOD
Sounds like a personal experience that didn't go so well.
Old Nov 20, 2014 | 11:50 AM
saccitycorvette's Avatar
LS1Tech Sponsor
Good info!
__________________
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
