ls6 or ls2 timing chain set
Old Nov 19, 2014 | 01:09 AM
97Lt1TA's Avatar
Default ls6 or ls2 timing chain set
from research i did some people had clearance issue using a double roller timing chain set and majority said to go with the ls2 timing chain.
is the ls6 timing chain similar to the ls2 timing chain?
Old Nov 19, 2014 | 07:31 AM
vettenuts's Avatar
If you buy a GM timing chain, you will get the same one. The older LS1 chain originally installed in our motors is no longer made.
Old Nov 19, 2014 | 08:14 AM
redbird555's Avatar
this^^. the ls2 is the current replacement. the ls6 is a little smaller but still plenty strong enough. Before 2005 thats all there was and there werent any issues. I had a new ls6 one when i did my cam swap and ts been fine now for 15k
Old Nov 19, 2014 | 08:16 AM
Paul Bell's Avatar
That's MISTER MODERATOR
The LS2 chain is thicker & beefier than the LS1/6 chain. It will fit on the LS1/6 sprockets. For most applications, the LS2 chain or a quality aftermarket single row chain set is all you need.
On my 383/AFR build, I used a single row Rollmaster chainset.
A chain tensioner/guide is never a bad idea.
Old Nov 19, 2014 | 08:19 AM
Paul Bell's Avatar
And like Redbird said, if you order a LS1/6 chain from GM today, you'll receive the LS2 chain.
Old Nov 19, 2014 | 11:43 AM
97Lt1TA's Avatar
thanks for the info. i think im just going to get a new ls2 chain and use my stock ls1 spockets .
Old Nov 19, 2014 | 03:15 PM
HINSON Motorsports's Avatar
If you need a good single roller timing chain check this one out from us. Its the new HINSON C7-R timing chain. It is the strongest single roller timing chain available. It has a seamless pin unlike all the other chains on the market that have a seam that makes the chain weak and stretch over time. Read up on it on our website. Heres a link
Link to HINSON C7-R Timing Chain
Old Nov 19, 2014 | 06:52 PM
Paul Bell's Avatar
Yep, that's the good stuff. Like the Rollmaster, it uses the IWIS chain.
