mild cam for low end
Old Nov 24, 2014 | 04:43 PM
patSS/00's Avatar
Default mild cam for low end
Thinking of something like this for a mild cam: 224/220 117+4, lift under .600, with non-agressive lobe profile.
This is for a street-only car that's stock internals with catback exhaust. Want a cam that produces a great low-end torque curve to 5K rpm. Don't care about over 5K (but don't want it to fall off a cliff), not concerned about getting max peak HP, prefer a flatter curve. Also want a stock idle. I do my own tuning so that's not a problem.
Looking for comments from the experts as to whether I'm in the right ballpark, or what you'd change. It seems like there are no longer any off the shelf cams like this (reverse or equal split).
Old Nov 24, 2014 | 05:02 PM
thunderstruck507's Avatar
I suspect a reverse split is the opposite of what you want on a car with restrictive exhaust
Geoff (former Thunder Racing, current EPS) used to use a lot of reverse splits such as the TR230 and even he seems to have swayed away from them, I think you're in the ballpark but I would go normal split or no split
Old Nov 24, 2014 | 05:13 PM
03Sssnake's Avatar
Good reading here - https://ls1tech.com/forums/advanced-...plit-cams.html
Old Nov 24, 2014 | 05:14 PM
03Sssnake's Avatar
Agreed for sure!
Old Nov 24, 2014 | 08:00 PM
redtan's Avatar
A reverse split might not be good for a stock manifold car when looking at overall power, but when trying to maximize torque under 5k that's actually not bad.
The main thing he would really gain by extending the exhaust duration is power up top. By keeping the exhaust duration short and thus delaying the EVO he's getting the most torque under the curve as possible at the expense of high rpm power.
Old Nov 24, 2014 | 08:34 PM
TXZ28LS1's Avatar
OP,
Do a search on stealth cams from MTI.
Old Nov 25, 2014 | 08:39 AM
Well let me put it this way...
I had a Comp 230/224 XE copy of the TR230 in my car. It went flat and I called Geoff and told him I wanted something slightly more powerful but keep manners.
He sent me a 230/238 with about .020" more lift. I swapped on some 799s with mild intake runner porting, no exhaust porting. The very first thing I noticed when driving the car after was the snappy off idle gains under the flash point of my converter. This combo makes more power everywhere over the old cam.
OP wants a stock power curve with more torque and stock idle. IMO he should get some 243/799s and mill them ~.030" and keep the stock cam. A friend did that with excellent results.
Old Nov 25, 2014 | 08:52 AM
96capricemgr's Avatar
Large duration and absurdly large LSA is not what you want for under 5000rpm power. IMO you are too large on both especially the LSA.
Old Nov 25, 2014 | 10:29 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
If you want low end power and don't care much above 5k rpms I would suggest something more like a 214/218 .595/.598 on a 110° LSA using LXL lobes. It will have the same overlap as a 224R cam on a 114 lsa but offer much larger gains in torque through the low end and midrange.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Nov 25, 2014 | 11:26 AM
03Sssnake's Avatar
I have a similar setup, had my 243s milled .020 and running a Futral F13 (BTR duals, LS7 lifters, BTR pushrods). The car just rips from off idle to 6500+, has been a great budget combo for my 99 F-boat.
Previously was running 853/241s with a bigger cam, this was a night and day difference.
Old Nov 25, 2014 | 12:25 PM
patSS/00's Avatar
Originally Posted by Sales3@Texas-Speed
If you want low end power and don't car much above 5k rpms I would suggest something more like a 214/218 .595/.598 on a 110° LSA using LXL lobes. It will have the same overlap as a 224R cam on a 114 lsa but offer much larger gains in torque through the low end and midrange.
Lonnie
What about idle with this?
Old Nov 25, 2014 | 01:00 PM
He said it is the same overlap as the 224 on 114lsa.
You are too accustomed to catalog cams with too much duration and a wide LSA used to tame it.
Old Nov 25, 2014 | 02:22 PM
Fry_'s Avatar
BTR stage 3 truck cam 218/224 .553/.553 113+3 . It's designed to make ton's of low end and mid range torque, should ible good with -5* overlap, and it's lobes are so soft you can use LS6 springs and stock pushrods.
Old Nov 25, 2014 | 02:55 PM
The cam that I specced would have a very mild chop to it and could easily be driven in a daily driver with great street manners given a tune. It would still work with a stock stall converter too if you have an automatic.
Lonnie
__________________
Old Nov 26, 2014 | 03:59 AM
99Bluz28's Avatar
With stock exhaust manifolds or shorty headers:
214/224 113lsa+4, it'll have a slight cam sound, but run very smooth with -7* overlap. I'd use Cam Motion lobes and tell them you want to keep the lift (@.05") under .600", or if you used Comp Cam lobes use the Xtreme RPM (high lift) lobes which would be lobe #3710 (214*) with .559" lift, and #3715 (224*) with .568". The IVC on the cam will also be 36*.
Old Nov 26, 2014 | 06:17 AM
Tuskyz28's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/1213394-baby-eps-cam-lays-down-430rwhp-415rwtq-track-results.html
Best baby cam that's proven yet in my book....
Old Nov 27, 2014 | 12:23 AM
Melba LS1's Avatar
To the OP I wanted similar results to what you want in a cam and chose a 595/598 210/214 114.
Didn't really achieve anything worth writing about. I think you will be disappointed if you don't go a bigger cam and hi stall etc and forget about the good idle.
Otherwise as others mentioned just do the heads with more compression. That would be my next mod if a lifter goes and gives me reason to.
Old Nov 27, 2014 | 12:25 PM
00WickedMaro's Avatar
Lonnie
Those low and mid gains would be awesome with that cam you spec'd... It would be a great daily driver cam... Good seat of the pants feel to.
Old Nov 27, 2014 | 01:49 PM
99Bluz28's Avatar
Yes if he's running LT headers, but with stock exhaust manifolds he really needs to be running more exhaust duration like 224* exhaust lobes, and to keep the overlap at -4* or more go with 112lsa.
Like this: 214/224 112lsa+3, with a 36* IVC and -5* OL.
Old Nov 28, 2014 | 11:43 AM
Felix C's Avatar
much good info there
https://ls1tech.com/forums/generatio...e-cam-ls1.html
