Ordered Mast Small Bore LS3's
Old Jan 24, 2015 | 09:10 AM
  #201
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Ok. Head gaskets:
I've got 3 different recommendations.
One says 5.7 or 3.910 cometics.
Another says the 4.035 cometics.
Both being the .040's, of course.
What's the proper head gasket for these things? While at Cam Motion we placed a stock GM 6.0/6.2 gasket on, and it looked like it barely fit.
I don't want excess gasket hanging inside, obviously.
What way do you guys normally measure chamber diameter. I'm not to enthused putting metal calipers on the inside of the chambers to measure. Maybe make a paper trace like you would an old headstone to read it, and measure that?
Thanks in advance
Old Jan 24, 2015 | 09:15 AM
  #202
miami993c297's Avatar
Originally Posted by dr_whigham
Ok. Head gaskets:
Thanks in advance
My guess reading your post is that you didn't purchase those heads from FlowTech...
Christian
Old Jan 24, 2015 | 10:22 AM
  #203
Rise of the Phoenix's Avatar
Dave, I'd check with a few vendors and engine builders and see which they would go with and why.
Old Jan 24, 2015 | 10:40 AM
  #204
dr_whigham's Avatar
The Scammer Hammer
Originally Posted by miami993c297
My guess reading your post is that you didn't purchase those heads from FlowTech... Christian
I bought them from Kip at Cam Motion. Got the whole tour of the place too. Amazing stuff going on in there... Just really cool!
That's the issue. Nobody im aware of has installed a set of these, which is why there's next to no info out on them. Even if Vengeance or anyone else answered me, it'd be the same responses I got, as they'd call Mast and ask too.
Old Jan 24, 2015 | 10:44 AM
  #205
A.R. Shale Targa's Avatar
You definitely don't want gasket overhanging the chamber or the bore.
The 3.91" is the obvious choice for the bore but it seems that the larger gasket was needed to not obstruct the chamber (if I understand you right)
Seems weird to me that a head designed for a 3.9" bore would have a CNC'd chamber which is larger than that. I mean sure it will effectively unshroud the valves but then what....there's a ledge sitting there and an even larger gasket quench area which wont properly burn and will elevate the BSFCs
I'm thinking a higher power is trying to coax you into a 4 X 4 combo
Old Jan 24, 2015 | 10:51 AM
  #206
dr_whigham's Avatar
The Scammer Hammer
It's just odd. One said 6.0/6.2, one said 5.7, but their engine builder there said 5.7 (3.910), but they said they've never built a motor with them, so it just threw me off.
When I get back home off the rig I'll pull em out again and caliper measure. It probably is the 3.910's.
Old Jan 24, 2015 | 11:34 AM
  #207
JakeFusion's Avatar
Super Hulk Smash
That gasket overhang into the chamber is blown out of proportion. It'll work either way. Into the bore is a different story.
What does MAST say?
Old Jan 24, 2015 | 03:17 PM
  #208
dr_whigham's Avatar
The Scammer Hammer
Originally Posted by JakeFusion
That gasket overhang into the chamber is blown out of proportion. It'll work either way. Into the bore is a different story. What does MAST say?
I know the 3.910 will fit the bore, no issues. The chamber... I got different answers from different people. I'm just going to measure it (the chamber) when I come home.
Old Jan 24, 2015 | 04:37 PM
  #209
Dave calls wife.....
Honey, you know those two really shiny expensive things that are in those boxes; Can you carefully remove one and take a tape measurement of the chamber casting around those two little round shiny valve thingies.....LOL
Less than 4 inches
four inches
more than 4 inches
Thanks babe you're the best !!!!
The LS1TECH community thanks you........
Old Jan 24, 2015 | 05:15 PM
  #210
Titokang's Avatar
I measured mine and they were 3.9ish, under 4" for sure. I'll measure em when I get home and post the result.
Old Jan 24, 2015 | 05:30 PM
  #211
dr_whigham's Avatar
The Scammer Hammer
Originally Posted by A.R. Shale Targa
Dave calls wife..... Honey, you know those two really shiny expensive things that are in those boxes; Can you carefully remove one and take a tape measurement of the chamber casting around those two little round shiny valve thingies.....LOL Less than 4 inches four inches more than 4 inches Thanks babe you're the best !!!! The LS1TECH community thanks you........
Hell no! She'll scratch the deck surface!
Sweet man, I appreciate it.
Old Jan 24, 2015 | 06:58 PM
  #212
Titokang's Avatar
They came in at 3.915
Old Jan 24, 2015 | 07:01 PM
  #213
Titokang's Avatar
Also I got a btr spring kit for my 241's and test fit the retainers and locks using the pull method and the retainer didn't drop so it got me thinking, but I'm a chicken ****......
Old Jan 24, 2015 | 07:52 PM
  #214
dr_whigham's Avatar
The Scammer Hammer
It's ridiculously close if you do the math, but I won't take a chance either.
Old Jan 24, 2015 | 08:20 PM
  #215
JakeFusion's Avatar
Super Hulk Smash
Get the 3.980s if that's true.
Open up the gasket too much and you actually lower compression.
Old Jan 24, 2015 | 09:41 PM
  #216
dr_whigham's Avatar
The Scammer Hammer
Get the 3.980s if that's true. Open up the gasket too much and you actually lower compression.
Exactly. I'll stick with the 3.910's from Cometic, .040.
Sound good to everyone?
Old Jan 24, 2015 | 09:59 PM
  #217
speedtigger's Avatar
Old School Heavy
I don't think you should put those heads on your car. They are far too pretty to actually install.
Old Jan 24, 2015 | 10:14 PM
  #218
dr_whigham's Avatar
The Scammer Hammer
Man I know. If they perform HALF as good as they look... Choooooo! I'll be happy, me!
I wonder if they're just begging for nitrous?
Old Jan 26, 2015 | 08:08 PM
  #219
Old School Heavy
Isn't everything?
Old Jan 26, 2015 | 09:01 PM
  #220
dr_whigham's Avatar
The Scammer Hammer
Isn't everything?
Well played...
