Ordered Mast Small Bore LS3's
Old Dec 20, 2014 | 09:32 AM
  #41
KCS's Avatar
KCS
Moderator
Originally Posted by Titokang
They are bronze guides but mast sells they're own billet stands for stock gm rockers.
But aren't stock rockers and bronze guides a no no?
Old Dec 20, 2014 | 09:34 AM
  #42
427zm's Avatar
Fly cut the Pistons, mill the heads to net you 12:1 and let it eat! I doubt you'll lose a thing under 4k at that point. Wait until the new fast or the MSD come out and the let it breathe! Congrats! Can't wait to see the results!
Old Dec 20, 2014 | 09:44 AM
  #43
Rise of the Phoenix's Avatar
Raising compression would help out any concerns you have with 4000 rpm and below power. Any idea how big of a cam you're going to want Dave?
Old Dec 20, 2014 | 10:08 AM
  #44
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Depends on who you talk to. On here, yes.
Speaking with, in my opinion, two of some of the highest regarded cylinder head guys in the business, they'd PREFER bronze. Yes you might eventually wear them out, but the wear rate is the same; slow and controlled. On a powdered metal guide, once it starts, it accelerates QUICKLY. Either way, the stands will be milled if needed to achieve proper geometry. I've also been told there's different types of bronze that are used in different heads. I'll leave it at that
With the valve angle I don't think I'll need to touch the pistons. And I'm just hoping the MSD fits under the cowl. It's taller then the Fast, which is bad news for us C5 guys...
I'm going to run whatever gasket and head cc I get told to by my cam / valvetrain guy. We're both EXTREMELY confident in my tuner
Old Dec 20, 2014 | 10:17 AM
  #45
kinglt-1's Avatar
I was also told by a local LSx builder that bronze guides were fine. I never mention it because anytime you think outside the box on this forum you get flamed...well unless you are mod.
Old Dec 20, 2014 | 10:34 AM
  #46
dr_whigham's Avatar
The Scammer Hammer
My name being green doesn't mean ****
Trust me; It's harder having an opinion or "thought out loud" bc as a greenie you're more quick to get called out, lol
KCS has literally built more engines than I've changed oil in all the cars I've owned. I HIGHLY value and respect him. I'm simply relaying what I've been told by a few high dollar head designers.
I learn A LOT here. I also keep an open mind. I don't "strictly" rely on the internet for everything I need to know. I pick up the phone, or drive and visit, with the latter being the more fun part
Old Dec 20, 2014 | 10:39 AM
  #47
kinglt-1's Avatar
Same here...I was just agreeing with your post. I agree KCS knows far more about building engines then I do. That is why I have never mentioned anything about using stock rockers with bronze guides even though I have been told it was fine by other LSx builders(over the phone).
Btw congrats on your purchase. Look forward to the build.
Old Dec 20, 2014 | 10:55 AM
  #48
dr_whigham's Avatar
The Scammer Hammer
I'm looking forward to it as well. It's going to be a while. All the parts will be acquired in increments. Blew my wad on the heads...
Old Dec 20, 2014 | 11:02 AM
  #49
A.R. Shale Targa's Avatar
Port speed is what matters most in the lower rpms. Yes compression as well as intake restriction can crutch this which is what the GM intake would do. Enhanced port speed in the 2500-4500 range while sacrificing upper rpm power....how much ?? Who knows as GM engineered it for an engine displacing 3.75 more cubes per hole.
As far as the bronze guide issue there are so many factors that apply. They tend to cool better and have enhanced lubricity however the seal ultimately determines how much oil it gets. You want enough but not too much and today's fuels are just SO clean and dry.
I thought Tooley felt the stock rocker met it's match at about .570"-.580" actual valve lift before it begins to scrub the valve tip. After all the deflections present most 600 range camshafts probably only move the valve this far. IMO .620"-.650" range would mandate nice true rollers.
Watching that spintron video also shows how much havoc goes on with the spring surge, valve bounce, and deflection when float occurs. Seven grand IIRC equals like 58 times/sec that each valve opens/closes. Again why a properly set up valvetrain matters so much and often shows up in that flat/smooth torque band.
One of Mamo's statements was "a compression trapping machine". Very true and I'm sure he meant much more than the static calculation.
Old Dec 20, 2014 | 11:19 AM
  #50
kinglt-1's Avatar
Good post Jim! I always enjoy reading them.
Old Dec 20, 2014 | 11:20 AM
  #51
dr_whigham's Avatar
The Scammer Hammer
I'm looking HARD at a set of Jesel's or Crower's. If that's the case, I might as well go solid roller...
Who knows. There's a lot up in the air guys. It's fun knowing they're ordered and being shipped and I can start ACTUALLY thinking about and peicing together the rest of the build.
Old Dec 20, 2014 | 11:37 AM
  #52
I run stock rockers and my AI Dart/RHS heads have bronze guides. No issues at all.
Old Dec 20, 2014 | 11:39 AM
  #53
Solid roller may not be a bad idea at all. Dave, shoot me a PM or text about your thoughts on the cam.
Old Dec 20, 2014 | 01:31 PM
  #54
KCS's Avatar
KCS
Moderator
I don't disagree with anything you just said, lol.
I just got a set of Trickflow heads so I've been doing my homework on the subject. Seems like it was a big deal on the old TFS heads as the geometry was different, but now the geometry has been "corrected" and it is more stock rocker friendly. I plan on running as much lift as I can on a stock length valve, so I'll be going with a roller tip anyways. I don't think a stock rocker will play nice with .700" valve lift.
Old Dec 20, 2014 | 03:54 PM
  #55
MuhThugga's Avatar
I know that Trickflow now offers their heads with powdered metal guides, which is good because you can now safely run the stock rockers without worrying about wearing out the bronze guides.
I just wish that someone would introduce affordable stainless roller rockers in a 1.7 ratio. I never cared for aluminum rockers.
Old Dec 21, 2014 | 01:00 PM
  #56
Titokang's Avatar
Old Dec 21, 2014 | 01:05 PM
  #57
Titokang's Avatar
poopy cell pics but thought id share a couple, stock valve vs 5.450 5/16 stem valves, psi 1511's vs k motion k800's, they are some heavy heads. stock 243 head i have lying around feels like its half the weight after holding the masts
Old Dec 21, 2014 | 02:46 PM
  #58
dr_whigham's Avatar
The Scammer Hammer
Those are some nice pics! Thanks! The valve difference certainly is substantial.
I don't get off the rig till the 30th, then I'll go pick mine up. I'll be sure to post all I can as well.
Talking to Brian now about those cryo-treated and micro polished LS3 rockers. Also scouring different sites for an LS3 intake with rails and injectors.
I wouldn't mind sending it to Peak Speed for radical porting...
Old Dec 21, 2014 | 03:39 PM
  #59
Titokang's Avatar
I think I paid 250 shipped for my ls3 intake from ws6store, the rail I'm gonna transfer over from my fast 102 setup. I've had 2 cams spec'd out pat g being one and martin@tick being the other. I see at least another 700 plus or minus on the cam/head bolts/gaskets/map sensor/tune.
Old Dec 21, 2014 | 04:26 PM
  #60
dr_whigham's Avatar
The Scammer Hammer
I'm a craigslist kinda guy. Looking at intake / rail / injectors for around 300. The LS2 TB must be made of gold, but that's another topic.
By the time I'm ready, I very well may have a medium runner Fast or MSD intake with a NW 102.
