Ordered Mast Small Bore LS3's
Old Dec 21, 2014 | 08:25 PM
  #61
A.R. Shale Targa's Avatar
Those head pics sure are sexy....quite a lot going on in that intake runner. The trailing guide vane seems to have a slight angle to direct the flow toward the spark plug area of the chamber. Curious as to what the CSA is on that 240 port ??
Old Dec 21, 2014 | 08:45 PM
  #62
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I am too. I'll prob call tomorrow and see what I can find out. I've "heard" it's really not much more than a standard 220 head or so, given the "length" of the runner.
Folks hear 240 and get worried, when it's the actual CSA that matters.
Old Dec 21, 2014 | 10:10 PM
  #63
LilJayV10's Avatar
Originally Posted by dr_whigham
Depends on who you talk to. On here, yes.
Speaking with, in my opinion, two of some of the highest regarded cylinder head guys in the business, they'd PREFER bronze. Yes you might eventually wear them out, but the wear rate is the same; slow and controlled. On a powdered metal guide, once it starts, it accelerates QUICKLY. Either way, the stands will be milled if needed to achieve proper geometry. I've also been told there's different types of bronze that are used in different heads. I'll leave it at that
With the valve angle I don't think I'll need to touch the pistons. And I'm just hoping the MSD fits under the cowl. It's taller then the Fast, which is bad news for us C5 guys...
I'm going to run whatever gasket and head cc I get told to by my cam / valvetrain guy. We're both EXTREMELY confident in my tuner
I saw that new intake at the PRI show a couple weeks ago. Definitely an interesting piece. Looking forward to your build.
Old Dec 22, 2014 | 09:25 AM
  #64
v8pwr's Avatar
Dave, keep an eye out for a tb on the corvette forum. I scored a 96mm ls1 type dbw for barely more than people want for the ls2. This tb is essentially an oversized stocker with 4 bolts. No wp clearance or tuning issues.
Old Dec 22, 2014 | 08:05 PM
  #65
dr_whigham's Avatar
The Scammer Hammer
Hmmmm. I could look for an LS3 Magnuson Heartbeat supercharger in the future as well... WAAAAY in the future.
Old Dec 24, 2014 | 11:04 AM
  #66
dr_whigham's Avatar
The Scammer Hammer
Just bought the ATI Damper, 10% UD with the high RPM material... Definitely going to do this build the RIGHT way!
Old Dec 24, 2014 | 11:12 AM
  #67
Rise of the Phoenix's Avatar
When have you not?
Old Dec 24, 2014 | 11:32 AM
  #68
Titokang's Avatar
Sweet, I got the standard size damper but had ati build it for 7k rpm.
Old Dec 24, 2014 | 12:18 PM
  #69
dr_whigham's Avatar
The Scammer Hammer
Originally Posted by Rise of the Phoenix
When have you not?
With the other build I think there was more power to be had... Could have ran thinner gaskets for better quench, flycut, ported the Fast... Rod bolts, lighter valves...
Only regret I have from that Camaro is not getting a time slip for it. Damn that thing was a BLAST to drive.
Old Dec 24, 2014 | 12:31 PM
  #70
Is flycutting on the table for this build? If so, you should really be able to increase power and torque.
Old Dec 24, 2014 | 12:39 PM
  #71
SCott5's Avatar
Subscribed! I have been looking at these heads for a year now just debating and I have talked to some well known shops and people and none seemed to have personal experience with them besides MAST of course. And like you searching comes up with nothing. There is one cam guy that has messed with them a lil but not on a boost application which I would use them for.
Keep us updated please!
  #72
dr_whigham's Avatar
The Scammer Hammer
I'd doubt it with an 11* valve angle. But I won't know till I order the cam and GET it.
I've got math to do as well. Very well could go solid roller... All up on the air right now.
Old Dec 24, 2014 | 12:40 PM
  #73
miami993c297's Avatar
Hi Rise,
From my personal experience, there is a lot of room to go with the camshaft timing before flycutting is required with the ETP heads...wich are the mothers of the MAST ones.
Christian
Old Dec 24, 2014 | 12:45 PM
  #74
Originally Posted by miami993c297
Hi Rise,
Christian
Thanks Christian, that's good to know. I've been doing some math of my own Dave to see how much I'd be out if I sold off my AI Dart/RHS heads, Tick cam, and LS6 intake/TB and bought these MAST small bore LS3 heads, custom cam, and LS3 top end.
Old Jan 3, 2015 | 05:03 PM
  #75
SCott5's Avatar
How high do you plan to spin this if you go solid roller?
Old Jan 3, 2015 | 05:53 PM
  #76
dr_whigham's Avatar
The Scammer Hammer
There's so many variables. Depends on what intake I go with, for starters. I don't see a polymer anything being able to supply it, and im not cutting on this car.
I'm more than likely going to stick with hydraulic. It's a street car. Just want something different.
As for how high... Depends on what the power looks like. I'll more than likely have Katech rod bolts in her, so I won't be worried about that. I can see 7200 being realistic... IF the combo dictates it.
Old Jan 3, 2015 | 06:26 PM
  #77
SCott5's Avatar
Didn't think Katech was still selling rod bolts?
I'm very interested in what kind of findings you will have. As it's either spending big money on a top end or bigger money with a whole motor setup.
Edit: Do you think the new msd May be your more obvious choice?
Old Jan 3, 2015 | 06:48 PM
  #78
dr_whigham's Avatar
The Scammer Hammer
Didn't think Katech was still selling rod bolts? I'm very interested in what kind of findings you will have. As it's either spending big money on a top end or bigger money with a whole motor setup. Edit: Do you think the new msd May be your more obvious choice?
That's what I'm planning on. It "might" be a stock or Peak Speed LS3 to get me by for a while. Other option is the Medium Runner Fast LS3.
Problem is NOTHING is in anyone's hands yet, so it's hard to decide what to go with.
I hope Tony looks at and tests the MSD's. I don't know if he has any brand loyalty with Fast or not though, so it's tough planning right now.
Old Jan 3, 2015 | 06:54 PM
  #79
SCott5's Avatar
Yea that seems to be the big problem with these small bore ls3s. It seems Ed Curtis likes them but other than that hard to find info
Old Jan 3, 2015 | 06:56 PM
  #80
Titokang's Avatar
You haven't gotten em yet? Since I ordered mine bare it took less than a week to get to me. Valves took about 3 weeks to a month. What springs are you going with?
