Best ATI Damper for me?
it takes Mass to absorb vibrations....and the underdrive pulley has less mass than the full size.
If the rubber material is doing its job, which by ATI's design it should then the hub material will do NOTHING because the rubber dampens all that is needed.Again how can you argue with real world results? Have you PERSONALLY experienced this happening? Show me one that has caused a failure. I can show you multiple times the stock STEEL/IRON one caused timing chain failures. Till then I'll keep spinning mine to 6900 and waiting for it the balancer to take out the timing chain.
As whigham said, I think I'm gonna trust the engineers at ATI instead of someone telling me that a stock dia balancer will make more power and that ATI doesnt know what they're saying when they recommend the 10% UD. Are you also aware that they offer different polymers that dampen differently in all their pullies depending on how you will be racing the car?
10% underdrive isn't bad, accessories usually work out fine for power steering and charging systems...especially since most likely you're idling the engine more than 10% higher RPM than the stock one did. If you idle down at stock RPM, the underdrive might cause you to get annoyed with power steering and your charging system when the engine is idling...25% you'll definitely be annoyed, 10% might not be.
Short of that...if it's a stick shift car, and you street drive it, and you've got a lighter flywheel/clutch assembly, it might benefit you a TINY bit to run a heavier material on the damper...it's effectively another flywheel...it's a small diameter though, so it's fairly insignificant in that regard...but in some cases that little bit of rotating mass can help.
actually the stock harmonic balancer isn't that bad if your staying in the 6500-6600 range, many people keep them.
I actually talked to kurt urban a long time ago about this and he said to keep the stock balancer if staying under 7000 rpm, the main reason ATI is a good upgrade is because most tracks require an SFI rated balancer at faster speeds.
once again, my opinion backed up by someone who knows a lot about timing chain failures, harmonic balancer and dampers etc...
