Best ATI Damper for me?
Old Dec 23, 2014 | 09:31 PM
adrynalinjunkie's Avatar
Default Best ATI Damper for me?
I currently have a 25% underdrive powerbond...
However since I am looking for big boosted power out of this 370" motor...
I think i might as well upgrade to the ATI....
I might be adding AC down the road but not until i am consistently running in the 8's and maxing out my 12 point cage
Any recommendations on what ATI damper would be best and what belt I will need?
This is a for a stock F-Body font accessory drive with power steering.
Old Dec 23, 2014 | 10:51 PM
Burken01's Avatar
All steel full size version, the ac pulley is removable so you can add it and take it off later if you wish..
UD pulleys don't dampen as well as the full size version, also the all steel version is the heaviest and will dampen the best out of all of them.
You're timing chain will thank you for it
Old Dec 24, 2014 | 12:22 AM
joecar's Avatar
+1 on ATI non-UD steel/steel.
Old Dec 24, 2014 | 08:25 AM
SSSTANG#1's Avatar
Call Rob at ATI.
Old Dec 24, 2014 | 09:29 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I wouldn't sleep on Innovators West... At least take a look at them.
Old Dec 24, 2014 | 10:16 AM
Thanks all, I will look into all of these.
Old Dec 24, 2014 | 10:28 AM
ckpitt55's Avatar
should probably look into pinning the hub also. not sure what the threshold is for when you need it, but it seems to be recommended for FI
Old Jan 12, 2015 | 03:25 PM
I called Rob at ATI today and he recommended a full size ALUMINUM
with the kit to pin it to the crank
He said a STEEL super damper would be better if I was running circle track and having rocks slung at it...
But for a street / track drag race car a Aluminum would be the way to go.
Any reason why you guys above recommended a STEEL damper?
Old Jan 12, 2015 | 03:33 PM
Burken01's Avatar
Originally Posted by adrynalinjunkie
I called Rob at ATI today and he recommended a full size ALUMINUM with the kit to pin it to the crank He said a STEEL super damper would be better if I was running circle track and having rocks slung at it... But for a street / track drag race car a Aluminum would be the way to go. Any reason why you guys above recommended a STEEL damper?
No daily driving?
Old Jan 12, 2015 | 04:09 PM
I will be driving a few 1000 miles a year on the street...but no gravel roads..
Have that many guys ruined Aluminum dampers on the street?
Old Jan 12, 2015 | 04:16 PM
Burken01's Avatar
I will be driving a few 1000 miles a year on the street...but no gravel roads.. Have that many guys ruined Aluminum dampers on the street?
not because of gravel lol
Steel is more durable for daily driving and it will dampen better than a lighter aluminum!
I've talked to all the guys at ATI and get different responses every time I called lol
Old Jan 12, 2015 | 05:54 PM
dr_whigham's Avatar
The Scammer Hammer
I myself just bought an ATI. Steel hub with an aluminum shell. It'll be perfectly fine. It's what's INSIDE that counts.
Old Jan 13, 2015 | 02:11 PM
Didn't even know that was a option...
I will get back to fabing the hotside and ponder this some more....
Old Jan 13, 2015 | 03:48 PM
bbond105's Avatar
I had a friend who ran aluminum under drive pulley set up on a SB and street drove it all the time. After a while the water pump pulley was worn through by the back side of the belt. Do these aluminum dampers that are driven regularly on the street have this problem?
Old Jan 13, 2015 | 09:19 PM
Burken01's Avatar
idk, but aluminum doesn't sound too durable for daily driving abuse..
Aluminum getting hot for a prolonged time doesn't sound durable.. At the track yes, since most runs last 10 sec or so
Old Jan 13, 2015 | 09:52 PM
redbird555's Avatar
you guys realize the asp and some other underdrives use an aluminum shell as well correct? I have been running my ati for 5 years and 30k miles and its never skipped a beat. Anyone who is running a 10% underdrive ati has the alum shell, only the standard size comes in steel. no worn out pulley grooves or belts on mine after all that time
Old Jan 13, 2015 | 10:08 PM
josh4ku's Avatar
The standard size steel is going to work the best...the aluminum will work also. But I would go with standard all steel.
Old Jan 14, 2015 | 05:46 AM
dr_whigham's Avatar
The Scammer Hammer
Why is it going to work "the best"?
Old Jan 14, 2015 | 06:10 AM
josh4ku's Avatar
The heavier steel dampens better than lighter material. If the aluminum was truly better stock vehicles would have them....yeah the aluminum is lighter but doesn't do its job as we'll as the steel. This is what burken01 said up top also.
Old Jan 14, 2015 | 07:17 AM
redbird555's Avatar
Lol wut? The material used on the shell has little to do with dampening. If you want to call the standard size dampener better that's fine. However it's because it physically has more surface area. The actual dampening material is inside the balancer. They actually don't like selling the ati 25% ud because it diminishes performance by not having enough material to effectively dampen. Nothing about material, that came from a rep at ATI not from an Internet site.
Does anyone here talking about the aluminum voodoo actually own an aluminum pulley let alone an ati? Like I said that came from an ati rep 5 years and 30k miles ago on my car. Yeppp, I think I'm gonna keep running my apocalypse aluminum shell and wait for it to explode lmao
Also as I said asp has used aluminum for years. They did have issues but none were related to the material they used. They're on thousand of cars today and I have yet to hear of a belt wearing through the pulley lol
