Lq4 cam and heads advice
http://store.cammotion.com/60l-truck...-compression-2
Here is a thread where a member installed the 5.3 version. He ended up gaining 40+ horsepower:
https://ls1tech.com/forums/dynamomet...hp-22rwtq.html
You know how it is with hot rodding, once you start stepping things up, you need other stuff to go with it. If you want to step up the cam, it is going to want a higher stall converter, deeper gear, headers, then maybe better intake, throttle body etc etc. Ask me how I know about the slippery slope. LOL
If you want a great hotrod setup that will have killer midrange torque and horsepower, I would consider this cam along with a Circle D 2B stall torque converter:
http://store.cammotion.com/60-ls2-34...-compression-2
http://www.circledspecialties.com/c-43-4l80e.aspx
I ran a similar combo in my car and it was very impressive for a mild setup.
Here is something else that may seem counter-intuitive: Even though the vehicle will spin the tire more easily, it will still accelerate quicker if you modulate the throttle. Here is an example. In my car, I changed from a 3000 RPM stall converter to a 4000 RPM stall converter. My 60 foot times at the track with good traction improved by .15 seconds and my 1/4 mile ET improved by .2 seconds. Now even when I spin and have to feather the throttle, I still run a bit quicker than I did with the old converter. In your truck, if you were to install a 3000 stall, the truck will go about 4 tenths faster in the quarter than it would with a stock torque converter. And even if you spin badly and had to feather the throttle, you would still outrun the times your truck would run with a stock torque converter.
