383 LS1 build
Lunati Forged 4in Crank
Diamond -2cc pistons
TSP 6.125 H Beam Rods
FAST 92mm Intake Mani and Throttle Body
Bosh EV14 52lb injectors with EV1 P&P adapter
Lingenfelter High Flow Intank GTO Fuel Pump Kit
Melling High Volume Oil Pump
Cloyes LS1/LS2-1x/LS6 Hex-A-Just True Roller Single Roller C5R Timing Set
Comp Cams "Comp R" hydraulic lifters
Monsters Stage 3 clutch
Drag Bags
Custom Cam from Martin
Tick Clutch Speed Bleeder
TSP engine rebuild Kit all the gaskets ill need hopefully and lifter trays
New arp 2000 rod bolts
New arp head bolts
Pushrods to be determined once its all together
Rotating assembly will come balanced with new bearings
Static CR will be roughly 12.1:1 on 93 octane
All thoughts and opinions welcome
Drag Bags
New arp head bolts
That is all you'll need! They flow ~39lb/hr at LS 58psi pressure. They flow as much as LS7 injectors and unless you are trying to make that power on E85 they will be plenty of injector for gasoline and are much better injectors than the older lucas/delphi fat body injectors. Relatively cheap for new pencil injectors too!
