Cam bearing question Ls1 ?
Mike
However you only need to replace the cam bearings if they show damage. Showing copper is normal. Have you measured the clearance with a dial bore gauge? Does the cam spin freely and smoothly?
If you do have to replace the cam bearings, I recommend to buy a tool ($200ish) and get OEM cam bearings, avoid the cheap aftermarket cam bearings.
http://carshop.carshopinc.com/produc...24334/CSP10900
Grab a pack of plastigauge and go to town.
I also use the CarShop Inc cam bearing tool. Old bearings out in less than 10 minutes, and installing new ones aren't hard at all as long as you take your time and pay attention. It's a pretty straight forward job.
