G5X2 and G5X3
Originally Posted by Lady Redhawk
If Comp Cams are making a cam for a company they will not make that same cam for an individual.
Its not malicious on their part to do so. Most shops are using off the shelf lobes, and simply choosing where to put the valve events on the cam. They can't say you aren't allowed to buy X off the shelf lobe + Y off the shelf lobe. The only caveat to this is if you have a custom lobe that you pay for a master for (at $500 or more per master most shops take lobes they already know work and skip this).
In that case, you as the individual couldn't use that particular lobe. But, if you look in the computer at comp you will most likely find a lobe on either side of your "custom" lobe which is almost identical.
In the case of most of the shops doing LS1 cams they use a Comp XE or XE-R lobe and they spec the LSA and ICL a few other use Lunati, or one of the other grinders out there, but you see lots of Comp cams out there...
I would also have an issue with not being given cam specs once I had purchased a package, and can understand folks perspective. But, I can also understand not giving away your R&D in a public forum...
We have done 2 propriatary lobes with Comp. They only hold them for 1 year unless you work the details out with them in advance. Then after that, they go on the shelf with the other lobes.
Thanks
Lou G
Thanks
Lou G
Originally Posted by obrien24
sounds like I would be a great candidate for the x3. But the price is a bit steep for me at the moment, damnit. I quess I will just have to wait for a little while.
ok wtf. i just read 14 pages of cam this cam that. i can pee this far and you cant blah blah blah.. where the hell is this video???? last post here was back in June.. I dont get a chance to live onsite at ls1tech so I may have missed it if it were posted in another thread.. but what gives. im rdy to see this g5x3 in action.....
S
EDIT: OK NM I FOUND IT.. seeign Godspeeds vette makes me wanna sell the SS, get a vette and give it to Lou for a while... bad as work Lou.
S
S
S
just got the cam installed ..... raced a Hamman M5 when it was stock(my camaro2001) and after installing the cam with all the bolt ons . when it was stock he was 2 cars ahead of me ...... but after one week he was counting cars between me and him ..he said 7-8 cars "me camaro infront of him"but i would say i was pulling all the way and that what i care for ... want to ask would it be a big difference "hp wise" if i switched from ls1 heads to pp ls6 heads 2.08 valves and will that make a p/v issue ??
i have a vid of both races..will try to post'em soon
thank u agian LG for G5X3 114
Originally Posted by BattyV6
All this information on these cams is great...I think I've made my choice of the G5X3 on a 114.
What else do you need for a cam swap?
-springs
-retainers
-pushrods
I've heard that it's good to do the timing chain as well, yes/no? Any other information would be great, even down to the smallest nut nd bolt.
Andrew
-springs
-retainers
-pushrods
Andrew
Originally Posted by TAGOES11S
Can someone confirm the G5x2 on 112 will fit with no pv clearance issues with the unmilled AFR 205 heads?
