Going with a TSP 228R Cam, and not sure what else..
I must have missed this part earlier. I've just been reading about the love/hate behind XER lobes. Realistically how often would I need to change springs? This car MIGHT see 2,000 miles a year. But I also don't want to be afraid to take in on 200-300 mile road trips.
then you'll be fine. XER lobes would wise to check the springs every 20k or so. road trips are fine. nothing wrong with those lobes its just that they are knocking on 15 years old and now you can get the same power from a lobe that is MUCH easier on parts. just the way technology goes
Super Hulk Smash
The heads/cam install is easier than installing the converter. I hate how GM packaged the transmission on this car.
But it should take you a weekend to do everything if you take your time. It took me a day to tear down my car and about a day to put it back together. It took about 9 months in-between...
I'd do the PRC Stage 1 LS6 heads with the TSP228, do the FAST 92, and the SS3600. If you do it yourself, you can get the heads in there.
And the XE-R makes power and is controllable. So it works.
The other option is to go with someone like Tony Mamo or Martin @ Tick and have them spec the cam and heads together and the cost is not much different. In fact, I believe Martin uses some of the PRC or TSP heads and can help you out with the right springs for the cam and the heads (as the PRC Stage 1s don't include valve springs).
Yeah, I don't see dropping the trans as being a fun job. I have dropped a few manual transmissions on mustangs, but this is the first auto trans car I've owned. I know the auto's are heavier than manuals, so that doesn't help. I still might try to do it myself, especially if I just spend the money on other parts..
I have seen a lot of people mention the PRC Stage 1 or 2.5 LS6 heads, but I don't see them on TSP's website... do they still make them? Or am I missing something?
Super Hulk Smash
I guess they did away with it. If you can get some 243s, it's only $750 if you send them in. But since you're going for a relatively mild cam, you can do the Stage 2.5 5.3L heads which have a higher compression and flow pretty close.
http://www.texas-speed.com/p-4345-pr...-outright.aspx
It's 1224 without valvesprings.
I'd actually do that and then grab this package from Vengeance with the VRX4 (228/230 camshaft - very similar to the 228R):
http://vengeanceracing.net/vengeance...-kit-plus.html
I like that package because it comes with everything except the head gaskets. Grab a pair of MLS gaskets and you'd have a nice budget build. It has the Comp Trunion kit, Melling oil pump, new timing chain, pushrods, valvesprings, etc. It's $1270.
So $2500 out the door for everything you'd need + fluids and the torque converter. It would be good for about 420rwhp. I'd wait on the FAST and either pick one up used or swap it on later since it's more expensive than the heads and offers less power.
Do not buy a Fast intake before heads.
Unless you have a dead lifter, do not put stock 799/243 on the car if you are on a budget, just get ported heads later on. IMO the gains are often inflated. I would reasonably expect ~15rwhp through an auto. That's a LOT of extra cost and work for 15hp just to need to send them off later and repeat those same costs (head gaskets, head bolts, and a lot of labor being the big ones).
LS1Tech Premium Sponsor
If you are going to leave anything out in that list then don't buy the Fast combo for now. That is something that can be easily added down the line and it's not a labor intensive project. You will gain a lot more by going with any of the other modifications on their own. Good choice going with the 2.5 5.3l heads on a budget. They will compliment that cam nicely and you will enjoy the bump in compression.
Lonnie
Lonnie
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Lonnie
Lonnie
Alright, so if I went with the 228R/5.3 head combo and ran my stock LS1 intake manifold, what injectors would I use? I'm betting my stock ones wont do..?
And if I do get new injectors now, will the work in the FAST 92 later on?
Thanks for all the support everyone. I greatly appreciate your input!
i would just use the stock heads and get yourself a slightly bigger cam than a 228. something like a 231/235 with the lsl lobes i think they are,.62x lift on a 113 with 3-5* advance and should be around 400 rw or so. i had a 228 cam with a m6 and was only around 380-385 rw with a pretty good tune. had lts,ory,hooker catback and lid.
400+ with an auto and that cam it would have to be a very,very happy dyno.a used fast 90/92 setup would help tremendously if your intake is an ls1 instead of an ls6.
Alright, after sleeping on it, I'm going to the 228R/5.3 Stg 2 combo and sticking with the LS1 intake for now. I might be able to spend a little more and getting something that makes more power, but honestly if I break 400whp I will be happy. It's just a street car that I drive on nice sunny days.
I'd like to reask my question from above - -what about injectors?
#32
Lonnie
__________________
#33
Super Hulk Smash
The Vengeance kit I like because it's one stop shopping - but you're right, you can buy everything separately. It just makes it easier for me to find and post one link ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The FAST 92 I'd recommend. The FAST 102 is a better intake, but if you're not going directly to it, it doesn't really make a lot of sense to buy things now and then buy more things later for it all to work (like the fuel rail adaptor kit). The FAST 92 fits the car better and can reuse your stock rails and whatever injectors you go with out of the box. Also, it would be easier to find it used and that's the way to go with the FAST to save some cash. They are really overpriced for what they are. Try to get a deal if you're on a budget.
The FAST 36s are a good choice.
#34
FYI, we do sell everything that you would need. It may not be in one specific package online but a simple call or e-mail and we can assemble one for you no problem. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Lonnie
Lonnie
__________________
#35
IMO, another good intake option is the BBK SSI. Yeah the FAST 92 is better, but it cost almost $300 more than the BBK, Furthermore it still makes a little better power than a LS6 even with the stock TB, and only cost $450-$490 new.
http://www.coloradospeed.com/bbk-ssi...6-p-30502.html
